No Power To Furnace Blower - HVAC - DIY Chatroom Home Improvement Forum
Old 07-02-2015, 11:55 AM   #1
Rewards Points: 28
No power to furnace blower
status code led is continuously off on furnace. Breaker is good, service switch with screw in fuse is good, fuse on control board is good. When I press door button the led should go on but it does not. Anyone have any ideas how I should troubleshoot this?
mmariluch is offline   Reply With Quote
Old 07-02-2015, 12:12 PM   #2
Rewards Points: 907
I would check the transformer for 24V.
Bitters is offline   Reply With Quote
Old 07-02-2015, 12:17 PM   #3
Rewards Points: 46
Voltage on either side of the transformer?
Cheers!
supers05 is offline   Reply With Quote
Old 07-02-2015, 01:09 PM   #4
Rewards Points: 7,440
Check your low voltage fuse.
With the door switch depressed, check for line voltage at the board, carefully.
user_12345a is offline   Reply With Quote
Old 07-02-2015, 01:57 PM   #5
Rewards Points: 28
Good transformer
Transformer is good - moved it to second unit to test and it works fine.
Old 07-02-2015, 02:05 PM   #6
Rewards Points: 28
No voltmeter
I don't have a voltmeter
Old 07-02-2015, 02:12 PM   #7
Rewards Points: 907
Try inspecting the back side of the control board.
Old 07-02-2015, 03:17 PM   #8
Rewards Points: 28
Back side looks good - heading out to buy a voltmeter
Old 07-02-2015, 03:19 PM   #9
Rewards Points: 28
View image in mmaruluch's Album on the left
Old 07-02-2015, 04:09 PM   #10
Hvac Pro
yuri's Avatar
Rewards Points: 1,838
Post the Brand name and model # of the furnace or airhandler.
Old 07-02-2015, 05:30 PM   #11
Rewards Points: 46
Knowing that the transformer works, is almost pointless as transformers very seldom fail. I want to know the actual voltage across both sides. We can move on from there.
Cheers!
Old 07-02-2015, 05:54 PM   #12
Rewards Points: 28
Verified with voltage tester that power is coming into the control board from door switch black wire. Put one lead from voltmeter on C and other lead on R and pushed in door switch - no voltage registered.
Old 07-02-2015, 06:00 PM   #13
Rewards Points: 28
Brand is Payne
model number is pg9maa060100aeka
Old 07-02-2015, 06:25 PM   #14
Rewards Points: 46
Was that the terminals on the board? What about the wires from the secondary? What about the primary side?
If it's not the fuse, it's a broken wire, or cracked solder joint on the board.
Cheers!
Old 07-02-2015, 06:28 PM   #15
Hvac Pro
yuri's Avatar
I am very familiar with that furnace. Check for 24 volts AC from Sec1 and Sec2 on the board. Secondary side of the transformer. Also check for 120 volts from L1 to L2 not ground.
Look in my album there is your troubleshooting chart or it is on the back of one of the furnace doors.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
blower problems with bryant furnace. blowerissue HVAC 4 03-13-2012 11:34 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
Payne gas furnace - blower fan running continuously Ed40 HVAC 0 02-05-2011 02:19 PM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 08:18 PM
