Old 09-19-2011, 11:31 AM   #1
No Power To Furnace
New to the site and any help would be appreciated. I went to turn on my furnace (Carrier) and it will not start. Checked the diagnostic blinking light and the code reads "secondary voltage fuse is open. Check for short circuit in secondary voltage (24vac) wiring." Can anyone tell me what the problem might be and if I can fix it myself? Thanks.
GravelGuy is offline   Reply With Quote
Old 09-19-2011, 12:45 PM   #2
JJboy's Avatar
No Power To Furnace
Check wires between thermostat and furnace for short, poor contact . Check transformer.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-19-2011, 06:10 PM   #3
Professional
No Power To Furnace
The fuse is on the control board located behind the blower door.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-22-2011, 11:00 AM   #4
No Power To Furnace
Thanksfor the replies! The fuse was blown. Replaced fuse and AC and blower work. As soon as I switch to heat, it blows the fuse again. Is it a short or transformer as mentioned earlier?
Old 09-22-2011, 11:31 AM   #5
Professional
No Power To Furnace
It is a short either in stat, wiring, or control board. Remove the wire from w on control board and then jumper R to W. Does the fuse blow? If yes, it is the control board or shorted wire in the furnace. If no, it is either stat or stat wiring. Report back and we can go from there.
IT IS WHAT IT IS
Old 09-22-2011, 12:02 PM   #6
No Power To Furnace
Just tried that and the fuse still blew.
Old 09-22-2011, 12:25 PM   #7
Professional
No Power To Furnace
Check all low volt wiring in furnace for shorts to ground. Check through all limit and safety switches. If nothing found then it is probably the board. Check all wires to ground for continuity.
IT IS WHAT IT IS
Power Surges?!?!!? drewsheez Electrical 9 04-03-2011 08:40 PM
Furnace fan power consumption? DIYGST Electrical 5 04-19-2010 02:00 PM
Gas Furnace Power Venter Problem JoBlowHomeOwner HVAC 6 10-17-2009 10:05 PM
furnace or electrical help tuasoi Electrical 13 11-29-2007 01:53 PM
furnace and or electrical problems tuasoi General Discussion 4 11-29-2007 01:50 PM
