Old 09-28-2009, 06:22 PM   #1
Question
No Power at Electronic Air Cleaner Junction Box
I have a Honeywell F50E 20 x 25 electrostatic cleaner and Trane XL80 TUD120R960A furnace which are about 15-20 years old. The power light will not light on the F50E power box and the air cleaner does not work. With a test light I found there is no power at the F50E junction box when the furnace/ac is on with a test light in the junction box receptacle. The receptacle checks OK. The junction box is located behind the air cleaner power box which plugs into the junction box receptacle. The door interlock switch does not appear to be in the power box circuit, since the wires come directly from the furnace internal junction box. This appears to switch power to the cells only. I have not check the interlock switch yet. What else should I check?
edge10 is offline   Reply With Quote
Old 09-28-2009, 08:26 PM   #2
as seen on tv
test for power from ifc board marked eac and neutral is it sending power to the device?
qbert is offline   Reply With Quote
How do I get power to a new ceiling fan? sestivers Electrical 12 04-25-2011 03:11 PM
Bring power to Ceiling Fan HELP mechcross Electrical 1 08-24-2008 06:45 PM
Electronic air cleaner is buzzing proofer HVAC 1 07-08-2008 09:26 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
