Old 11-09-2010, 03:13 PM   #1
No power to circulating pump on boiler.
I have heat upstairs but not downstairs. I was able to determine that the cartridge circulating pump isnt getting power from the furnace. When I disconnected the pump from the furnace and applied power from a separate power source. The pump ran fine and circulated hot water through the registers. Im assuming there is a switch that supplies power to the pump. The pump is wired to 2 screw terminals that are on a small circuit board inside a small metal box labeled Honeywell. How can I find the mechanism that supplies power to the pump?
Thanks in advance.
draft34 is offline   Reply With Quote
Old 11-09-2010, 04:29 PM   #2
Hvac Pro
You did. Post pics of it (circuit board thingy) and the boiler and make and model # and we may be able to help.
Old 11-09-2010, 05:30 PM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,... Find the model #s on the Honeywell controller,...
Sounds like you need a New 1...
Old 11-09-2010, 07:14 PM   #4
The name and number of the controller my circulating pump is connected to:
Honeywell Aquastat relay type L8148E. Mine is vertically mounted. You can see a pic if it here at this link:
http://customer.honeywell.com/techli...0s/60-2278.pdf
Old 11-09-2010, 07:47 PM   #5
Bondo's Avatar
Ayuh,... A little Well McClain boiler I just put in my rental house has the same controller, the horizonal mount...
If you don't have Power at C1, 'n C2, then you need a new 1...
They're not a servicable item for diy'ers, or even Burner Techs for that matter...
Old 11-10-2010, 01:18 AM   #6
I checked for current across C1 and C2 while the furnace was on. There was no current.
Old 11-10-2010, 08:10 PM   #7
Professional
your board in the the honeywell box is called an aquastat, sounds like the relay on the board that controls power to the circ pump is bad, you need a new aquastat
hvactech126 is offline   Reply With Quote
Wiring New Thermostat for Heat Pump AND Boiler Sweetpea_cmb HVAC 3 10-28-2010 02:29 PM
Re: Pump Control test Franklin msenkpiel Electrical 1 08-04-2010 08:22 AM
power steering pump replacement issues joey219 Automotive Repairs 2 10-08-2009 04:14 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
retrofit pump on gravity boiler InquiringMind HVAC 3 07-31-2009 03:20 PM
