No Power To A/C Or Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2013, 10:41 AM   #1
Smile
No Power to A/C or Heater
Hello, I have a Payne Heater and cannot remember the A/C brand. We last used the A/C in August, all month. We went to fire up the heater and it does not work. The thermostat clicks on and flashes "heat" (normal) but the blower never comes on. We then tested the A/C and same thing. Does this mean we have a bad blower? The breakers are not tripped
tjk34 is offline   Reply With Quote
Old 10-29-2013, 11:46 AM   #2
Experienced HVAC Tech
HVAC1000's Avatar
Remove the thermostat and with the furnace doors all in place and all the proper switches on take your meter and check for 24v AC between R and W or Y or G. Then report back
HVAC1000 is offline   Reply With Quote
Old 10-29-2013, 01:17 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,842
try checking for 24 volts between R and C on the circuit board with the door switch pressed in. if none then a fuse may be blown. check for 120 volts coming into the furnace as there may be a wall switch shut off or other problem. post the model and serial # and some pics with both doors off.
power vent water heater detroittigerfan HVAC 2 09-21-2013 08:17 PM
Event Production power distribution, I want to do it right. mattvivsound Electrical 0 07-13-2012 08:54 AM
How can I tell if I need a power vent water heater? ... speedmaster Plumbing 2 11-01-2011 10:37 AM
Rheem Power Vent 2 Water Heater jrf0022 Plumbing 3 09-25-2011 05:06 PM
Power vented water heater noise mainstreetprod Plumbing 1 02-06-2009 10:26 PM
