No Plenum? Mass Of Flex Duct All Bunched Together. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 05:17 PM   #1
Rewards Points: 81
No plenum? Mass of flex duct all bunched together.
So a couple years ago, I had a new rooftop unit installed on my house here in Phoenix, AZ. Its a 3.5 ton Lennox unit and it replaced a very old Carrier unit. The installers added a second return to the system at the same time and ran a bigger/better supply to the kitchen than the one that was there. They also put in a new roof jack.
I always assumed there would be a plenum up in the attic that all the ducts then attached to/ran off of. I was hoping to do my own duct work for a project I'm working on, but I went up there this weekend for a plumbing project and did a little exploring while I was up there. I found that there is just a massive tangle of flex duct running from where the roof jack enters the attic with no where to tap in for new lines. I also noted that at least one of the flex line has a 180 degree turn in it before making a further 90 degree turn.
What the heck? Is a plenum not required? Is it so small that the mass of flex duct conceals it?
The company that did the work is one of the most respected in the city with all kinds of ethics awards and lifetime workmanship guaranties, etc. Do I have a legitimate gripe here? Should I at least have someone come out and look at it?
JeepNick is offline   Reply With Quote
Old 02-14-2012, 05:41 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Picture?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-14-2012, 06:01 PM   #3
Rewards Points: 13,446
Why would you not call them and ask them?
Old 02-14-2012, 07:31 PM   #4
Sow us some pics before you go medieval on them.
hvac5646 is offline   Reply With Quote
Old 02-14-2012, 08:21 PM   #5
Rewards Points: 314
call them and ask them to come out and look. I would read up on the best practices for flex duct. I think you will find that yours is not up to "standards". (my experiance is that most are not)
While your at it, you might ask them how they would add a new run.
If you have a 270 degree turn in a flex and its not done right, you could have really high static pressure. This will shorten the life of the equipment and also make you electric bill higher.
There are so many things to look at and for, so pictures would be best...
btw, what part of town are you in??? I am in mesa/tempe.
bobinphx is offline   Reply With Quote
Old 02-15-2012, 11:30 AM   #6
Rewards Points: 81
I'll get some pictures this weekend when I go back up there to run wires for smoke detectors. In the meantime, I may just have the guy come out and look. Since they want $2500 in new business from me, I'm betting they will.
Using flex duct for return. lakeresident HVAC 3 11-14-2011 09:56 AM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Jenn-Aire Downdraft - OEM flex duct required? Dwizzo Appliances 0 10-09-2010 04:35 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 06:20 AM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 08:28 PM
