09-23-2012, 04:41 PM
#1
No new dope on gas leak fix, how long will it last?
I recently had my gas pipe fixed. The contractor took apart, redoped and put back together several leaking/loose couplings. There is one leaking pipe-coupling connection where he could not remove the pipe, so he only retightened the pipe one full rotation without applying any new dope.
My question is how long will this particular connection last? Is it likely that it will leak again in the near future because of the lack of new dope?
09-23-2012, 06:39 PM
#2
If he could get a full rotation on the pipe that was leaking, it sounds like the pipe was loose. If that pipe was originally doped and was only loosely tightened, then fully tightening is an acceptable practise if it then stops it from leaking.
09-23-2012, 07:25 PM
#3
Professional
Pipe dope is only for lubricating the threads to allow the pipe to be tightened enough to seal. The pipe dope does not actually seal the pipe.
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
The Following 5 Users Say Thank You to hvactech126 For This Useful Post:
09-23-2012, 07:54 PM
#4
I concure. it will be just fine...
09-24-2012, 09:40 AM
#5
Thanks guys.
09-24-2012, 12:34 PM
#6
To verify all the leaks were property fixed, have your local utility come out with a hand "sniffer" and check for leaks. Better to be safe than sorry!....
09-24-2012, 12:45 PM
#7
According to wikipedia..."pipe dope" is both a lubricant and a sealant. Just interesting but not really pertinent to this thread?
http://en.wikipedia.org/wiki/Pipe_dope
09-24-2012, 02:51 PM
#8
Most references I have seen say that the variation and coarseness of pipe threads require dope to get a positive seal. I am not a pro and in the few gas jobs I have done I have had only one leaking joint (tiny, tiny leak) and it did not respond to extra tightening. I had to take it apart and redope it. But like the guys say, the real test is if it is leaking or not. If not, you are good to go.
Live long and prosper.
09-24-2012, 03:29 PM
#9
They checked it, it's not leaking now. I'm not sure how long the fix will last though
09-24-2012, 05:53 PM
#10
Every gas leak I ever repaired was due to someone relying on the pipe dope to seal the joint and not tightening the joint enough, Don't loose sleep over this...you will be long gone before it ever leaks again if it was tightened properly.
09-24-2012, 06:07 PM
#11
The male ends of the pipe are slightly tapered so if it's tight it won't leak. Don't worry about it.
The Following User Says Thank You to Marty S. For This Useful Post:
09-25-2012, 02:57 PM
#12
You guys are awesome, I appreciate the help.
09-25-2012, 06:03 PM
#13
An old Tradesmen
Except for electrical conduit. Pipe threads are tapered, both the male and female threads, they form an air and liquid tight metal to metal seal without a sealant. Pipe dope, or thread lubricant is needed to reduce friction while tightening.
Thread sealants are used/needed on non tapered threads to make them air and liquid tight.
PS: Some electrical companies do use tapered threads, but it is not required.
The Following User Says Thank You to beenthere For This Useful Post:
09-25-2012, 10:08 PM
#14
Originally Posted by techpappy
Wikepedia is a pseudo encyclopedia...it's full of opinions and half facts.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
09-25-2012, 10:40 PM
#15
The hell they will seal, pipe dope is need to seal the pipe tthreads on gas, water and air! The threads are tapered so they tighten up. If pipe dope was just to lube the threads, the cutting oil would do to seal the joint!
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
