Old 06-13-2008, 11:41 AM   #1
No Hot water
We just replaced our air conditioning unit in our house, the installer said he replace the coil for the furnace too. Since then we have not had any hot water. Could this be the coil? or just the flick of a switch somewhere?? Its late Friday morning and we are unable to get a hold of the guy! HELP!!
Stay at Home is offline   Reply With Quote
Old 06-14-2008, 04:25 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
No Hot water
Only if you have a Boiler, and your water comes from there. If you really want to find out, go get on your hand and knees in front of the Water Heater and look to see if the Pilot is lit. Most likely the contractor either did not turn back on the gas, or forgot to light both pilots.
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
Water Mystery - Sump Pump Set Right? robertr4836 General Discussion 4 02-13-2008 03:32 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
