No Heat: Pressure Switch & Hoses Forming Traps - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-21-2010, 03:05 PM   #16
Hvac Pro
yuri's Avatar
Rewards Points: 2,318
Replace the pressure switch, they are cheap and develop intermittent sticking problems. Try cozyparts.com a Lennox dealer but Lennox owns AireFlo so they may get you parts. The gas valve has nothing to do with the pressure switch.
Old 12-21-2010, 05:01 PM   #17
AKA HVACTECHFW
Rewards Points: 1,208
dumb valve is probably the problem
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-21-2010, 05:10 PM   #18
That's a safe bet.
Wiggle the wires going into the gas valve yooper. Those valves are well known to be trouble makers.
Old 12-21-2010, 05:18 PM   #19
Hvac Pro
yuri's Avatar
It may be but the press switch codes go thru the circuit board separate from the dumb valve on the first models so they are separate. I have replaced a bunch of those switches on units 5-6 yrs ago when we sold them.
Is the code from the green light on the gas valve or one from an LED on the circuit board?
Old 12-22-2010, 09:54 AM   #20
Rewards Points: 32
The green light is on the gas valve...don't tell me I've been barking up the wrong tree this whole time...? If so, my apologies for being uninformed.
Yooperman906 is offline   Reply With Quote
Old 12-22-2010, 09:57 AM   #21
Rewards Points: 32
I blew some more water through the condensate trap last night, situation is still as described above. I'm a little confused as to why water being in the condensate trap would ever be an issue...isn't there supposed to be water in there?
Anyways, I guess I'll shop around a bit for a pressure switch in case I need to order it. Not sure where I'm going from here, but I really appreciate all of the advice given so far...thanks!
Old 12-22-2010, 10:07 AM   #22
Rewards Points: 32
Originally Posted by Marty S. View Post
That's a safe bet.
I'll be glad to give that a try...I've read about corrosion on these wires, but none seems evident. Will try wiggling wires.
Old 01-04-2011, 09:52 AM   #23
Rewards Points: 32
The latest update. Situation is still as described above (can work it by turning gas control off, then on).
Found a pressure switch from Lennox for $82 - maybe I should order that and try it, but need to test it first to be sure it's working or not.
Wiggling wires on the gas control does not seem to have any effect.
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
Ruud heat pump high pressure switch mikethe ductman HVAC 3 07-28-2010 06:00 AM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
Pressure Switch Stuck Closed --heat works but A/C doesnt assassinmunky HVAC 0 06-23-2009 02:49 PM
What engages pressure switch? dfferg HVAC 1 09-12-2005 10:27 PM
