No Heat, Need Help - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2012, 06:17 PM   #1
No heat, need help
I have an RPJ heat exchanger, it's a comfort maker. The burners will not light, when I switch to manual the blower will not come on. When switching to A/C, the a/c will not come on. There is a loose wire by the blower motor junction box. Also checked the breakers, checked door switch, turned off pilot light and reset it.
garykeahey is offline   Reply With Quote
Old 10-30-2012, 06:39 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Take a picture of the loose wire/inside of the furnace and post it. Does the board have an led light that's on?
Thanks.
Doc Holliday is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 08:07 AM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 04:50 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
