#16 |
Roofmaster
no heat for me
Hi Doc. I tried to tighten up one of the lugs for a spade connection and it just broke off and fell away. I soldered on all new ones, as I figured I got the first Chinese lot on my furnace. We have reached the level of acceptance where manufactured parts do not even serve the purpose for which they are intended. Quality Control? A Joke.
It absolutely amazes me that even spade lugs can be made like crap today. Where will it end?
" A lot of men build things, and a lot of things fall down " |
#17 | |
no heat for meQuote:
oh, wait. now i understand. no, i would never grease the contacts (i used the wrong word). i meant connections = terminals. and i do not use a lot of grease, just a thin layer. whatever coating they use on these terminals, is designed to go bad after a while. seen it a lot of times.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. i didn't make this world. i just live in it. be careful of whom you make fun of. one day, that could be you... |
| Display Modes | |
| Heat won't stop running, just installed new thermostat | NorthSidePK | HVAC | 28 | 11-01-2012 11:05 AM |
| dual fuel heat pump - no heat without propane | sweetfarm | HVAC | 3 | 10-11-2012 09:07 AM |
| VisionPRO Setup Functions & Heat Pump | infoskr | HVAC | 31 | 03-18-2010 02:15 PM |
| Comparison and Heat Pump Selection help... | ChrisDIY | HVAC | 7 | 03-06-2010 09:34 PM |
| Heat Pump Woes | Zenica | HVAC | 50 | 01-27-2009 08:37 AM |
