No Heat...help - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-18-2008, 07:04 PM   #16
okay i will try that real quick i will let you know what is on the jbox so you can advise me which 2 to use to jump it. I am asuming you mean the panel the power wires are going to after they come from the safety switch on the lower door?
buhler is offline   Reply With Quote
Old 10-18-2008, 07:26 PM   #17
NO! CHECK J BOX FOR LOOSE NUETRAL (WHITE WIRE).
tHE PUSH BUTTON ON THE BLOWER SECTION THE BOTTOM PANEL.
REMOVE THE WIRES FROM THE SWITCH AND JOIN THE FEMALE END CONNECTORS WITH A PIECE OF METAL OR WIRE.
hvaclover is offline   Reply With Quote
Old 10-18-2008, 07:27 PM   #18
Okay here is where the wires run to..from the safety switch they go to a box, the name on the box is "Heatcraft" model # FTC5-EH01 , on the right hand side of the box at the top it has a wire at a plug that says "Limit" , then below that on the right hand side it says "Valve". On the left hand side at the top it says "COM" and below that it says "24 vac". In the center there is 2 wires going to 2 plugs with a label over both saying "Blower" 1 goes to a plug labeled "com" and 1 goes to a plug labed "NO". From there they go up to the top of the furnace to another box it is a "Honeywell" along the right hand side of that box there are 7 wires and from the top it says:
Spark no number
TH-W #7
24V #6
24V GRD #5
Burner GRD #4
PV #3
MV/PV #2
MV #1
does that help you any?
Old 10-18-2008, 07:34 PM   #19
THOSE ARE THE CONTROLS we'll get to those.
Listen careful now: the switch on the outside of the furnace that shuts off power, should look like a light switch. Do you have a switch like that to turn power on and off to furnace?
Old 10-18-2008, 07:39 PM   #20
yes i do..there is power to there and past it to the furnace
Old 10-18-2008, 07:44 PM   #21
OK, the wires from the swich attach to the furnace power wire, locate the spot where the switch wires join up with the furnace wires.
Old 10-18-2008, 08:05 PM   #22
Okay i taced the wires into the furnace..they join up inside the furnace at the top left hand side..there they are just tied to 2 other black/white wires..they go down and into a panel by the lower motor. The white wire splits..one end goes to what looks like a coil of some sort and the other wire goes to a plug that leaves that box and heads to the motor. The black wire also splits when it enter the box...1 goes to the same coil as the white on did and the other goes to the back of a 7 wire plug area.
Old 10-18-2008, 08:16 PM   #23
Are thy joined with wire nutS?
Old 10-18-2008, 08:25 PM   #24
with merets or i guess wire nuts..(yellow)..they both are tied with merets and head down into the furnace. The white goes straight to the lower panel, but the black of course goes to the safety panel switch and then to the lower panel also. I have good power to that point i know for sure(on the black that is)
Old 10-18-2008, 08:42 PM   #25
Turn the light switch on the furnace off. Remove the wire nut (they should unscrew).
Once you have the wires from the switch disconnected turn the switch back, check across the black and white wire. Should Be 120 volts.
Make sure of the voltage and tell me what it reads. Before you answer I want you to check the black wire from the switch to ground and tell me what it is .
Old 10-18-2008, 08:54 PM   #26
it is 120V....
Old 10-18-2008, 09:04 PM   #27
Reconnect the wires.
In the blower section is there a metal box with the the letters W C R Y and R.
What we are looking for here is the theromostat wire connection.
The heat wire goes to W terminal and should be white in color.
There is also a R terminal with a red thermostat wire to it.
There is a C terminal. There should be nothing connected to it unless you have air conditioning.
Locate these and tell me.
Old 10-18-2008, 09:15 PM   #28
okay there are a ton of wires and they go as follows;
"C" white wire
"W" white wire
"R" white wire
"Y" has 2 a red and black wire going to it
"G" has a white wire
yes i have central air.
somebody has had them apart as they are all marked with duct tape on each one.
Old 10-18-2008, 09:32 PM   #29
Making progress now, good.
OK, these will tell a big part of the problem.
Make sure you reattach the Yellow wire nuts to the wire they came off.
Once you make sure they are on good and tight I want you to turn the light switch on the side of the furnace to "ON".
Push in the safety switch (might have to wedge it closed). Make sure the thermostat is turned all the way up.
With the safety swich pushed in check R to C. you should have 24volts.
Tell me when you do that.
Old 10-18-2008, 09:41 PM   #30
i have NOTHING, i checked the wires all are tight but no current
Help with Air Handler and Aux Heat kulkarni_ash HVAC 5 10-06-2008 08:05 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
New Thermostat- Heat comes on when on "Cool" daviar HVAC 3 06-29-2008 05:24 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
