Old 01-06-2013, 02:53 PM   #1
Post
No heat.... HELP!
ok, was washing clothes and fuse blew, turned back on the fuse and everything came back on but the furnance.... any sugguestions
*up the creek w/o a paddle*
Shawnie is offline   Reply With Quote
Old 01-06-2013, 02:58 PM   #2
No heat.... HELP!
its a HEIL N9MP2 model
Old 01-06-2013, 03:14 PM   #3
I'm Your Huckleberry
No heat.... HELP!
Fuse where? Circuit breaker? fuse in the furnace? if a circuit breaker tripped on the furnace due to you washing clothes than you may need an electrician to separate the line circuits if they're being shared.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Shawnie (01-07-2013)
Old 01-06-2013, 03:17 PM   #4
No heat.... HELP!
fuse box, i know its semi working or trying to because its humming but thats all
Old 01-06-2013, 03:27 PM   #5
No heat.... HELP!
may have blown 2 fuses...check them again....furnace may have caused fuse to blow same time washer running..either way..could be burnt out motor in one of the units... so after you replace all defective fuses they may blow again..leave washer off make sure all fuses good and try furnace again.somewhere to start...
techpappy is offline   Reply With Quote
The Following User Says Thank You to techpappy For This Useful Post:
Old 01-06-2013, 03:31 PM   #6
No heat.... HELP!
i did, i checked all fuses, everything is working but the furnace
Old 01-06-2013, 03:42 PM   #7
HVAC Tech/ Browns Fan
No heat.... HELP!
You better call a pro on this one. You may have over load fuse box and maybe some wiring problems. This is not worth doing something totally wrong and start a fire.
Tator1076 is offline   Reply With Quote
The Following User Says Thank You to Tator1076 For This Useful Post:
Old 01-06-2013, 03:46 PM   #8
No heat.... HELP!
thanks
Old 01-06-2013, 08:27 PM   #9
Roofmaster
No heat.... HELP!
Do you actually have fuses that screw in and are the size of standard light bulb bases, or are you calling your circuit breakers fuses?
Other poster is right about circuits, the furnace should be on a seperate home run.
" A lot of men build things, and a lot of things fall down "
The Following User Says Thank You to jagans For This Useful Post:
Old 01-06-2013, 09:57 PM   #10
No heat.... HELP!
I have push in fuses in my circuit box
Tags
help me please, hvac, no heat
Heat won't stop running, just installed new thermostat NorthSidePK HVAC 28 11-01-2012 11:05 AM
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 09:07 AM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 31 03-18-2010 02:15 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
