| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Ford Explorer & Mercury Mountaineer: Reconnecting AC & Blower Motor
by Expert Village
Here we're demonstrating how to change a heater core on a late model Ford Explorer or Mercury Mountaineer. In this step we're going to talk about the proper service procedure for reconnecting your air conditioning lines to the evaporator, and plugging in... Read More »
How to Troubleshoot Split Phase Motors
by eHow.com
If your appliance is not working properly and has a split phase motor, you may be able to repair the problem yourself. Resolving the problem with your split phase motor can be fairly easy once you determine what the problem is. Read More » Here we're demonstrating how to change a heater core on a late model Ford Explorer or Mercury Mountaineer. In this step, we're going to talk about the proper service procedure for removing your evaporator core and blower motor box from the vehicle. The... Read More »
How to Wire Car Accessories
by Expert Village
We must access the wires by removing the dash panel and tapping into accessory 1, accessory 2, ignition 1 and ignition 2 and starter position. of course when tapping into those circuits, we must fuse protect the circuits being tapped into and must not... Read More »
How to Remove Parts for Valve Cover Replacement
by Expert Village
Hi, my name is Nick McCullough on behalf of Expert Village. In these clips we're going to talk about the proper way to remove and replace an engine valve cover, that is cracked, excessively worn, rusted out, or otherwise defective. In this clip we are... Read More »
