Old 08-31-2012, 02:00 PM   #1
no heat in base board
I just convert my old cast iron radiator to a base board heater, I turned on the heat to check for leaks now i am not getting any hot water up to the heater. All of the other heaters are getting heat except the new heater. Any help would be great?
Bigpetey is offline   Reply With Quote
Old 08-31-2012, 02:14 PM   #2
Did you purge it? there should be a valve on it to release the trapped air
Dwillems is offline   Reply With Quote
Old 08-31-2012, 02:47 PM   #3
biggles's Avatar
you don't need to turn it on for leak checks just let the pressure reg feed the 12psi in and the check it and as suggested bleed from the highest point...
Old 08-31-2012, 02:49 PM   #4
Yes..you have to bleed the air from the new rad. Should be vent screw at top and end end of rad. Loosen/open it. You will hear air coming out. Shut off once water starts coming out and no signs of air, i.e., hold bucket or plastic container under /over bleed screwuntil water runs out without any more air sounds, then shut off valve and you should have circulation/heat.
Make sure the system water is cooled off before doing this.
techpappy is offline   Reply With Quote
Old 08-31-2012, 02:52 PM   #5
what's your boiler pressure?
takes 10 pounds just to get to the second floor.
you may have to raise the pressure up to 15-20 so you can bleed it then drop it back down.
i used to have to raise the pressure up to 25lbs so one of my customers could bleed the radiators on the 3rd floor then i would drop it back down.
you have 2 threads for the same thing
HVAC condensor fan outside intermittant wheelsup HVAC 21 05-24-2012 11:25 AM
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 08:48 PM
Lenox heat pump circuit board /compresspr charles58 HVAC 5 11-29-2010 10:38 PM
HELP? Control Board Fixed Heat...But Now A/C Won't Turn On - Homeowner KLR HVAC 35 08-15-2009 11:46 AM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
