No Heat Or Air In Upstairs - HVAC - DIY Chatroom Home Improvement Forum
Old 03-12-2009, 03:41 AM   #1
no heat or air in upstairs
We had a new furnace and central air installed last year.we get very little heat or air upstairs.We had new ducts ran upstairs and cold air return.Is there anything to do to fix the problem?
pbus60 is offline   Reply With Quote
Old 03-12-2009, 05:53 AM   #2
An old Tradesmen
Rewards Points: 6,516
Best thing, is to have the installing contractor come out and fix it.
You paid them for a working system.
Are there balancing dampers in the supplies.
Old 03-17-2009, 10:53 AM   #3
Balance diffusers
I would try closing most of the down stairs diffussers in the cooling season to force more air upstairs and I would check the new work to be sure you have enough air supply and returns to the upstairs.
SULTINI is offline   Reply With Quote
Old 03-17-2009, 02:01 PM   #4
Milord, methinks it is closed dampers; it's not always easy to tell what is open or closed from the handle.
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
No Heat to Upstairs kuzzy HVAC 4 03-01-2008 02:58 PM
Please Help No Heat Upstairs Radiator Downstairs Is Fine !!! CARL7480 HVAC 3 02-13-2008 03:46 PM
Please Help No Heat In Upstairs Radiator Downstrairs Is Fine CARL7480 Plumbing 15 02-13-2008 09:17 AM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 06:47 PM
