No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-14-2010, 11:31 PM   #1
no heat
goodman heatpump (package unit) works fine until outside temp reaches 35 degrees or below,then blows cool air
litt1966 is offline   Reply With Quote
Old 11-15-2010, 05:36 AM   #2
An old Tradesmen
Rewards Points: 6,112
How long does it blow cool air. Could be going into defrost. And the aux heat not working.
Old 11-15-2010, 07:25 AM   #3
It will run like that blowing cool air as long as you let it run.
Old 11-15-2010, 07:27 AM   #4
AKA HVACTECHFW
Rewards Points: 1,208
do you have gas or electric backup? Sounds like backup is not working
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
litt1966 (11-18-2010)
Old 11-15-2010, 07:36 AM   #5
Stick a thermometer in front of a register and post the temp of the supply air and the room temp. Does the thermostat show a drop in temp or is it staying stable?
Old 11-15-2010, 07:44 AM   #6
Electric backup. The room temp drops. Thanks for the replies.
Old 11-15-2010, 03:18 PM   #7
Does the outside unit run when it is blowing cold? Could have a low temp lockout and the aux is not energizing.
SKIP4661 is offline   Reply With Quote
Old 11-15-2010, 03:59 PM   #8
An old Tradesmen
Check your air filter. And also check to see if the outdoor unit is actually running when it is blowing cold air.
Old 11-18-2010, 08:14 PM   #9
Thanks for the help,it seems that someone turned off the breaker for the backup heat.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 08:49 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
