No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-12-2010, 06:53 PM   #1
no heat
what do i do if my heater wont blow heat
Earl ` is offline   Reply With Quote
Old 11-12-2010, 07:34 PM   #2
Fire comes on but no blower? See if the blower motor has high voltage going to it or not would be the first step. If it does then replace the otor and/or capacitor. If it doesn't replace the circuit board or relay that's supposed to power it.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 07:49 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
