Old 11-25-2012, 12:12 PM   #1
Post
no heat
Furnace will not run consistantly,it will glow for start up then go out,some times it will stay lit and most of the time it will go out,it will glow for ignition then go out,and restart.I believe its the ignition control or the integrated furnace control,(had to look that up).its a White Rodgers Model 50A50-405 120v, it says to replace with CNT1309 D340035P01,looked them up unable to find either,the light flashes 3 times at times and stays solid other times,can anyone help?
gettoplumber is offline   Reply With Quote
Old 11-25-2012, 03:09 PM   #2
An old Tradesmen
no heat
Look on the legend to see what 3 flashes means. Could have a safety that is doing its job.
The Following User Says Thank You to beenthere For This Useful Post:
gettoplumber (11-26-2012)
Old 11-25-2012, 05:36 PM   #3
no heat
3 flashes says pressure switch problem,it has been replaced,but still happens,sometimes i get different codes that flash, its not consistant. I'm thinking its a circuit in the control board problem? have looked up the part and White Rodgers says they have no such part,so it must be out dated looked up replacement and couldn't find that either.I have gone down and just moved the wires,it clicks a few times then it will start up and then shut down again,sometimes it will stay on after messin with them and most of the time it won't,haven't seen any bad connections,gas valve is good.
Old 11-25-2012, 07:06 PM   #4
An old Tradesmen
no heat
Pressure switch code doesn't mean the pressure switch is the problem. It means something is preventing it from closing.
Old 11-25-2012, 07:17 PM   #5
no heat
as beenthere says it may be something causing the pressure switch to do its job....or it may be the pressure switch itself.....
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
Old 11-25-2012, 07:37 PM   #6
Items wanted: Time
no heat
out of 8 billion pressure switch faults, in my experience, the pressure switch has been the problem about 3 of those times.
NiNe O is offline   Reply With Quote
The Following User Says Thank You to NiNe O For This Useful Post:
Old 11-25-2012, 08:02 PM   #7
no heat
well....... maybe a few more than three....I however agree many switches that were doing there job have been thrown away..... it usually is something causing it......
Old 11-26-2012, 12:05 PM   #8
no heat
exactly just because you get a pressure switch fault doesnt mean that the pressure switch is bad it means that somthing is keeping it from closing. In my opinion your board is probably bad if your getting different codes at different intervals
bclark24 is offline   Reply With Quote
The Following User Says Thank You to bclark24 For This Useful Post:
Heat won't stop running, just installed new thermostat NorthSidePK HVAC 28 11-01-2012 11:05 AM
dual fuel heat pump - no heat without propane sweetfarm HVAC 3 10-11-2012 09:07 AM
VisionPRO Setup Functions & Heat Pump infoskr HVAC 31 03-18-2010 02:15 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 09:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
