No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 09-27-2012, 09:29 AM   #1
No Heat
I have an arcoair (LP) model# n8mpn100f14a1. When I turn the heat on the flame comes on for a few seconds then goes out. How can I remedy this?
redfan is offline   Reply With Quote
Old 09-27-2012, 10:26 AM   #2
Rewards Points: 1,296
Not having anymore info than what you gave is going to make it tough to diagnose right now.
My inclination is from what you have said though is that the flame sensor may need cleaning.
Can you provide more info on this unit as their web site does not have a search function to look up that model #
danpik is offline   Reply With Quote
Old 09-27-2012, 10:44 AM   #3
No Heat
The units fan was tuning on and off at random about a week ago, then stopped. when I turned the heat on we got nothing. I called out a tech and he said he thought the control board was bad. sense then I have pulled the flame sensor and attempted to clean it with emory cloth. i have gotten it to run for a couple minutes but it doesn't try to re start un less I shut the power off then turn it back on.
Old 09-27-2012, 04:43 PM   #4
Did the tech replace the control board? If the flames come on for a couple minutes but no blower then it has to be a blower control or blower motor.
Old 09-27-2012, 05:14 PM   #5
No Heat
He did not. The quote was $600 and was simply too much at this time. Besides i didn't have a good feeling about this guy.
A couple times that it did start up it was on long enough for the blower moter to start. then it would shut down.
Old 09-27-2012, 06:04 PM   #6
Rewards Points: 582
need alittle more furnace info... picture would also help...
Old 09-27-2012, 06:50 PM   #7
Not sure what else to say. If you have a question I can answer
Old 09-27-2012, 06:55 PM   #8
possiale the control baord is locking it out thats why you have to reset board by turning off the power .,is there any led lights on the board ?
hvac dude is offline   Reply With Quote
Old 09-27-2012, 06:58 PM   #9
There is not. The board model # is 1014460. Replaces st9160b
Old 09-27-2012, 07:05 PM   #10
sensor nice and clean ? only one ? ive seen two on some furnaces, wire good from senor to baord ? does unit still fire runs for few seconds then shuts down ? no retrys
Old 09-27-2012, 07:14 PM   #11
I cleaned the sensor,and the tech said that all the wiring was good.
Also , watching the tech, when I jump the tstat on the board was when I got a response. But still short. I just put a new tstat on and no response.
Old 09-27-2012, 07:15 PM   #12
Rewards Points: 582
control board could control blower through a timer relay....which in turn will trip high limit if blower don't come on...... tech could be right... bad board..
The Following User Says Thank You to ben's plumbing For This Useful Post:
redfan (09-27-2012)
Old 09-27-2012, 07:17 PM   #13
jumped at board ? you jumped what teminals at board ? if you turn up stat nothing happens ?
Old 09-27-2012, 07:19 PM   #14
Rewards Points: 582
sorry this old man either can't see or read
Old 09-27-2012, 07:21 PM   #15
On the board, terminals are on the right. From the bottom , the first one and the third one. Same as tech did..
Nothing with new stat. Even on 80
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 04:50 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
