No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 08:34 AM   #1
No Heat
I have a white rodgers model 50E47-843 controller on my gas boiler, the yellow light is flashing. I have checked and have the proper polarity, with 120v coming out, the glow plug is lit, vent fan is running, but no heat..
bposivak is offline   Reply With Quote
Old 01-31-2012, 08:57 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
does it have an error code legend on the sticker for the control or in the owners manual for the boiler? that led may be telling you the problem. U should be getting 24 volts AC across the 2 terminals of the gas valve after that plug glows for 7-30 seconds. check your gas meter outside and if U have a gas water htr or other appliances do they work.
Old 01-31-2012, 09:05 AM   #3
hey, yes it does have an error code legend, the flashing yellow light means "improper polarity". i have checked the pins and do have 24v, in correct polarity, on the pins, also have 120v coming out on the L1 pin. gas water heater, and gas stove both work.. glow plug stays light all the time.. i am wondering if it is possible the controller module is bad?
Old 01-31-2012, 09:10 AM   #4
Hvac Pro
yuri's Avatar
could be but I would check the grounding first. make sure you have continuity from the ground to the boiler AND the plate the board mounts on to a copper water line and use a cheater wire if necessary. there may also be a grd term on the board and with the power off U should get continuity to grd. otherwise the board may be giving a false code and shot.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 04:50 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
