No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 02:05 PM   #1
no heat
i have electric heat with acc and heat from 1. the heat comes on but does not blow out warm or hot air. what causes this?
truhdc is offline   Reply With Quote
Old 01-14-2012, 02:08 PM   #2
help me!
Old 01-14-2012, 02:10 PM   #3
Rewards Points: 13,444
Your post is impossible to read, and makes no since, try again with model #, ser. #, picture, something so someone can help you.
hvactech126 (01-14-2012)
Old 01-14-2012, 03:17 PM   #4
i dont know all that my furnace has a filter on top connected to a duct. i have an outside unit that has a fan and is responsible for the a/c and heat. my thermostat has a/c, off, heat, and em heat. my problem is when i turn my heat on it kicks on and blows but doesnt blow warm air at all. i dont understand why b/c everything looks to be working fine. i even put a new filter in it but still. over the course of last night i had the heat on all night set to 78 but the tempeture nevewr rose it actually dropped to 61. what can i check or do any suggestions would help i do have a child in the house.
Old 01-14-2012, 03:28 PM   #5
With your very limited knowledge we are not going to be able to help you......call a local heating company, they have people on call who will be more then happy to come out and help you.
harleyrider is offline   Reply With Quote
Old 01-14-2012, 04:01 PM   #6
biggles's Avatar
shut the stat OFF then the 2 breakers....one for the indoor fan and one for the outdoor condenser....then back ON and reset the stat to heat..lets hear back
Old 01-14-2012, 04:38 PM   #7
I'm Your Huckleberry
Rewards Points: 2,270
Reversing valve, defrost board and\or refrigerant.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-14-2012, 05:13 PM   #8
Houston204's Avatar
Rewards Points: 556
The model number is on a tag on the panel.
Pictures can be posted on this site using www.photobucket.com
If this is too complicated I agree with Harley, you should call in a pro.
Houston204 is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heat Pump Thermostat HELP!!! MichaelG HVAC 22 12-09-2010 04:50 PM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
