No Fan With "auto" Setting On HEATING - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 10:36 AM   #16
I'm Your Huckleberry
Rewards Points: 2,270
http://www.youtube.com/watch?v=BhENu...eature=related
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-19-2011, 01:01 PM   #17
Originally Posted by perkolator View Post
Ok, so I need a cam stat limit controller. Do you have a place to recommend purchasing one? I'm in Sacramento area but don't think I'll be able to get to a store during the week - so online retailer would be easier.
Are they all the same or is there a specific type I need to go with this old unit? Lastly, how do I wire said controller? Does it just have 2 connections (one for the yellow fan wire and one for the black wire off the heat sensor?) or is my wiring rigged beyond just 2 wires being in the wrong spot?
All this is seriously a big help. I can't believe the serviceman would leave the heater like this. But it was a few years ago now and we never noticed until like 9months after he left. You think the wiring looks bad now...shoulda seen it before he worked on it!
Cracks in heat exchanger - this would have to do with leaking burnt fuel/CO into the "clean" air right? I'm sure it can happen but I don't think ours has a crack.
http://www.furnaceparts.com/Store/Category/Camstat.aspx
harleyrider is offline   Reply With Quote
Old 12-19-2011, 01:02 PM   #18
Originally Posted by Doc Holliday View Post
nice video......
too bad it wont help this guy in the least bit, although it may confuse him even further.
Old 12-19-2011, 01:37 PM   #19
ok, so after watching these videos and checking the parts catalog it looks like everything for heat is supposed to be linked to the limit controller as it will turn on/off the gas as well as the fan. well i definitely have the controller and it's obviously doing something since it it turning on/off the gas, but not the fan. I don't see a way of knowing whether or not it works properly unless ALL the wiring is correct on it first, which it obviously isn't since there's a wire not connected to anything.
thanks for the videos though, they both helped understand what the controller does, but don't help me get it wired properly since those are both different than mine. i'm wondering where I can find the proper wiring for this so I can reconnect the disconnected wires and either make it work or get it all correct before I start diagnosing broken parts that aren't fully installed. I tried google searching the model number for a wiring diagram but came up empty handed. can't read it in the pics, but here's the model: 21LU 080A 2M1
side question: is the fan's on/off controller for the A/C function different than that for the heat or are they separate contollers? because that seems to work just fine.
perkolator is offline   Reply With Quote
Old 12-19-2011, 04:15 PM   #20
The a/c blower is energized by a relay located some were in the control area.
Old 12-20-2011, 11:11 AM   #21
So...anyone with wiring tips for me? Do I need to make a diagram of whats going on in that spaghetti and list where each wire currently goes?
heat pump system is heating when on cool setting every 3-4 days???? tommy56 HVAC 4 08-09-2011 08:24 AM
Burner always stops at LOW setting on L8124L pleasehelpmike HVAC 2 01-19-2011 09:22 AM
Radiant floor heating questions secutanudu HVAC 35 03-08-2010 02:04 PM
Hydrokientix Heating System Not Heating damonl73 HVAC 11 12-18-2009 06:12 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
