No Emergency Cut Off Switch On My Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2009, 12:16 AM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
No emergency cut off switch on my furnace
I never really realized till now, but my furnace has no cut off switch. Should I add one, and is there any specific location it needs to be in? Normally they're near the stairs to go to the basement. Do I just add it to the circuit that feeds the furnace, or does it have to be wired in any special way like through the furnace or something?
Old 10-13-2009, 06:56 AM   #2
An old Tradesmen
Rewards Points: 6,112
At stairs/entrance door to basement.
Add in series to circuit feeding power to the furnace.
Old 10-13-2009, 09:15 AM   #3
Wire Chewer
Rewards Points: 46
Cool that's what i'll do, should be fairly easy. The wall going downstairs is actually behind the furnace so I just need to add a jbox and run a short wire to a switch.
Old 10-13-2009, 11:30 AM   #4
An old Tradesmen
Code technically wants the switch outside the furnace room.
But, in many areas, inspectors allow them to be just inside the door of the basement.
Can't tell you what your area allows.
Old 10-13-2009, 12:40 PM   #5
Wire Chewer
Rewards Points: 46
Think I'll be fine, as while the switch will technically be in the furnace room, it will be facing the opposite side of the wall which is the stairs area. I just need to find some kind of red "emergency" plate so people don't think it's a light switch. I've seen that happen. "every time grandma comes over the furnace stops working".
Old 10-13-2009, 06:48 PM   #6
Wire Chewer
Rewards Points: 46
Heh I just followed the wire, turns out there is one. It's pretty much behind a shelf behind the furnace. Not the most accessible area. At least I know I have one now so I won't worry but I may consider changing it location at some point.
Old 10-13-2009, 07:11 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
Check HDepot, Rona, Canuck Tire. They may have a red cover.
Old 10-13-2009, 07:38 PM   #8
biggles's Avatar
HD has the cover plates,and if you do it at the top of the stairs put it high on the wall so it doesn't get knocked off when you going down with stuff.
Old 10-13-2009, 08:09 PM   #9
Hvac Pro
yuri's Avatar
Had that happen once, Buddy threw his laundry downstairs and flipped the switch. Not real happy with an emergency call out charge.
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
Goodman gas furnace getting 3 flashes, stuck pressure switch chuck2009 HVAC 4 11-03-2010 12:42 AM
Furnace Kill Switch Sophist HVAC 15 12-31-2008 01:53 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
HEIL furnace keeps kicking off reset switch sunsetacres1318 HVAC 8 11-04-2008 09:35 AM
