I never really realized till now, but my furnace has no cut off switch. Should I add one, and is there any specific location it needs to be in? Normally they're near the stairs to go to the basement. Do I just add it to the circuit that feeds the furnace, or does it have to be wired in any special way like through the furnace or something?
Cool that's what i'll do, should be fairly easy. The wall going downstairs is actually behind the furnace so I just need to add a jbox and run a short wire to a switch.
Code technically wants the switch outside the furnace room.
But, in many areas, inspectors allow them to be just inside the door of the basement.
Can't tell you what your area allows.
Think I'll be fine, as while the switch will technically be in the furnace room, it will be facing the opposite side of the wall which is the stairs area. I just need to find some kind of red "emergency" plate so people don't think it's a light switch. I've seen that happen. :laughing: "every time grandma comes over the furnace stops working".
Heh I just followed the wire, turns out there is one. It's pretty much behind a shelf behind the furnace. Not the most accessible area. At least I know I have one now so I won't worry but I may consider changing it location at some point.
HD has the cover plates,and if you do it at the top of the stairs put it high on the wall so it doesn't get knocked off when you going down with stuff.
Had that happen once, Buddy threw his laundry downstairs and flipped the switch. Not real happy with an emergency call out charge.:thumbsup:
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
