No Cycle - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 11:14 AM   #1
no cycle
have a new utica mgb-100hid w/ elec ignition and a damper, damper opens ,circulator runs , no spark no flame
gwhite958 is offline   Reply With Quote
Old 01-25-2009, 11:21 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
Is it a boiler? How new, does it have a warranty. Do you have gas to the house, any other gas burning appliances that work.
Old 01-25-2009, 02:02 PM   #3
biggles's Avatar
the flue damper is not traveling its full stroke to close the burner cycle........put a channel locks on the damper rod sticking out the other side of the flue damper and continue to turn it......should hear a CLICK that is the ignitor.if it does come on set the damper to fulll open for now till you can check it out
GE washer - spinning cycle does not work proofer Appliances 7 08-26-2008 03:14 PM
washer spin cycle seems wrong markm Appliances 5 01-04-2008 01:10 PM
Lennox, ignites, won't cycle jeddy1 HVAC 2 12-11-2007 06:53 PM
Air Handler leaking when cycle ends mannaserv HVAC 1 09-04-2007 09:02 AM
