Old 11-11-2012, 09:09 PM   #1
Unhappy
No cooling after capacitor/condenser fan motor replacement
Just finished replacing condenser fan motor and capacitor on Goodman heat pump. Have heating but no cooling.....????
ddave55 is offline   Reply With Quote
Old 11-11-2012, 09:31 PM   #2
reversing valve in heating mode.... many possibilities.... heat pump guys will be around soon.... i hate them and never install them.... mind you its no wonder it goes to -40 here a lot
carmon is offline   Reply With Quote
Old 11-11-2012, 10:58 PM   #3
Heating in heat pump mode only? No resistance back-up?
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
ddave55 (11-11-2012)
Old 11-11-2012, 11:38 PM   #4
I am in Phoenix, AZ. Had an idea it might have something to do with reversing valves. But what does that have to do with condenser replacement? Thanks for responding
Replace just the Cooling Unit for Condo HVAC System acj74 HVAC 19 07-22-2012 03:03 PM
Cooling capacity relation with air temperature. Samart HVAC 2 06-23-2011 08:39 PM
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 04:21 AM
Wiring a Ruud RGTK-06E series furnace for 2-ton cooling bolo_invictus HVAC 3 01-25-2010 04:24 PM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 10:56 AM
