No Blowing Air - HVAC - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 02:04 PM   #1
No blowing air
I live in a double wide mobile home. Along the front wall in my living room, I have 2 air vents. On this same wall further down in another room, an air vent blows hard. After an inspection, I had to crawl underneath and fix 2 torn ducts. The 2 air vents in my living room still do not blow air. My outside unit is brand new so I know its not the actual unit. I am assumming the ducts are blocked. Is there an easy way to check for bocked air passages? Or is there another problem this rookie home owner doesnt know?
Williams974 is offline   Reply With Quote
Old 08-03-2011, 02:08 PM   #2
Jackofall1's Avatar
When under neath did you run the unit to see if there was any air at the connection point?
How did you fix the ducts that were torn?
Did you inspect the torn ducts for something that may have crawled up inside them?
Old 08-03-2011, 03:10 PM   #3
fabrk8r's Avatar
Did you replace the torn duct with flexible duct or hard-pipe?
If you used flex make sure there are no kinks. hard pipe would be better for air-flow and to prevent critter intrusion.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
New AC & Furnace not blowing enough air dficken HVAC 13 07-28-2011 06:21 PM
Cool air blowing, house not cooling helping friend HVAC 3 07-23-2011 07:25 AM
Stops blowing cold air after several hours awathen HVAC 4 06-07-2011 08:31 AM
Hardly any air blowing out vents and lights dim every few minutes girlnamedjo HVAC 7 05-26-2011 12:29 PM
Outside unit blowing cold air johna_d HVAC 1 04-10-2011 10:38 PM
