No Blower (Lennox G11Q3E) - HVAC - DIY Chatroom Home Improvement Forum
Old 04-02-2007, 07:27 PM   #1
Suddenly, the blower has stopped working.
It still ignites the burners, but the fan never turns on. I don't see any fuses or breakers to reset. Is it worth getting it fixed since it is so old, or should I have it replaced?
"Technical" Terry is offline   Reply With Quote
Old 04-02-2007, 10:21 PM   #2
Do you have a volt meter and do you know how to use it to trouble shoot ?
harleyrider is offline   Reply With Quote
Old 04-03-2007, 01:13 AM   #3
Rewards Points: 150
yeah, check for (lack of) voltage at the motor itself to rule out the motor itself being bad,
elementx440 is offline   Reply With Quote
Old 04-03-2007, 08:54 AM   #4
I have a DMM, but there are so many wires going to the motor (eight, I think, I'm at work right now) I'm not sure which should or should not have voltage.
If the blower motor is bad though, should I have it fixed or replace the entire unit? I know that the furnace is pretty old, and I am not sure how much effort or money to put into it. Is anyone familiar with this make and model to say which direction I should take?
Heat comes on but blower never does aczer HVAC 12 02-13-2011 07:57 AM
For all you Lennox owners ibwahooka HVAC 9 11-23-2008 05:06 AM
Heat Pump blower speed? ktkelly HVAC 1 07-18-2007 11:01 PM
Induction blower seal ktritz HVAC 4 03-05-2007 09:52 PM
Troubleshoot Blower Motor - Lennox LongShot HVAC 2 12-29-2006 07:30 PM
