No Access To HVAC Evaporator Coil - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 07-24-2013, 08:56 AM   #16
Jay, how did it turn out?
I just cleaned the coil in my rental unit. Man, that was some nasty junk on the coil - about 1/8" thick and nasty. I got it off though. I also had to install a safety switch in the secondary drain, because the installer left it wide open and the tenants heard water leaking (secondary drain) from the closet where the unit is installed, plus they used 1/2" drain pipe. I took care and now the unit is good to go.
Hope all worked out for you.
Methodical is offline   Reply With Quote
Old 07-24-2013, 09:48 AM   #17
Rewards Points: 35
I haven't gotten around to doing it. Here in Jersey, it's been very hot lately and I didn't want to fiddle with it at the moment. Did you have access to the coil or did you have to cut it open?
jay235 is offline   Reply With Quote
Old 07-24-2013, 10:05 AM   #18
Fortunately, I had access at the front - no cutting. I can understand not screwing with things until it cools down a bit. We had that heat down here in MD, too. It's a bit cooler today. Do you plan to install the safety switch - it's an easy install (see below). Cheap insurance.
http://ows.rectorseal.com/Safe-T-Switch-SS2.php
http://ows.rectorseal.com/product-da...2/inst-SS2.PDF
Old 07-25-2013, 01:08 PM   #19
Rewards Points: 35
I cut out the duct today and opened up the inside of the a-coil. Not much dirt/gunk at all which was pretty surprising given the system is over 15 years old. I guess the regular change to the air filter helps. I still sprayed on the coil cleaner and then sprayed on water since I had opened it up.
Old 07-25-2013, 04:24 PM   #20
An old Tradesmen
Rewards Points: 8,184
Did you cut a hole so that you are looking at the inlet or outlet side of the coil. Outlet side usually does look clean, when the inlet side is dirty.
Old 07-26-2013, 05:29 AM   #21
Rewards Points: 35
Yes - I opened the panel so that I can also see the inside of the coils. Both sides looked pretty clean.
Old 07-26-2013, 06:57 AM   #22
An old Tradesmen
Usually, when I go to all the trouble to cut open a plenum to inspect a coil. I spray it with cleaner even if it looks clean. just to make sure.
Old 07-26-2013, 12:23 PM   #23
Rewards Points: 35
Yes, completely agree with you. I did spray with the coil cleaner.
Old 06-03-2017, 09:43 AM   #24
SouthLake's Avatar
Rewards Points: 14
Re: No access to HVAC Evaporator Coil
I have a similar situation as OP.
this system was installed about 2 years ago before I bought the house.
One side has excellent access. front and rear def not. side facing return has okay access, not ideal. I have never had a unit where there is no panel to pop open to view the coil. this is pretty dumb design...
I would like to be able to clean this thing, and install a UV light while im there.
The sheet metal wrap around the coil appears to be attached as a "U", with the opening facing the side with all the pipes. The back of the U has about 2 inches of clearance behind it against the wall argh.
so do i just take tin snips, slice open one side of this thing (nearest the wall). that will give me access to clean the coil? then put the metal back and seal it with tape?
im afraid to go cutting this box without knowing whats on the inside of the sheet metal or the orientation of the coil...
maybe i should use my HVAC guy and have him do the opening for me and go from there.
SouthLake is offline   Reply With Quote
Old 06-03-2017, 10:27 AM   #25
Hvac Pro
yuri's Avatar
Rewards Points: 396
I would recommend you get the HVAC guy AND he should do a proper maintenance checkup. Most important part is to check the freon level which a DIYer cannot do without gauges etc.
The furnace also needs maintenance as there is a flame sensor which needs cleaning. Not that easy to get at or out on that furnace.
Old 06-03-2017, 10:35 AM   #26
SouthLake's Avatar
Rewards Points: 14
Thanks,
I have the gauge set from installing and charging my garage Mitsu Mini-Split, but this system is new to me. the mini split is easy...
if he's going to be here to cut access i might as well get him to do everything, but once i have access id like to be able to clean this on my own going forward. im just reluctant to go slicing open the metal with the coil behind it... and that seems to be whats recommended is this thread.
Old 06-03-2017, 11:33 AM   #27
Hvac Pro
yuri's Avatar
Rewards Points: 396
You can do it and I can describe it but what's the point if he can do it?
It looks like you have a expensive Signature series furnace and some nice toys so I would get it checked properly and maintained.
Old 06-03-2017, 02:11 PM   #28
Rewards Points: 8,228
You should not have to clean a coil after 2 years or ever.
The filter is supposed to keep the system clean.
also the secondary heat exchanger will capture most of the dust, very little will go to the coil.
it's not normal maintenance, it's a repair cause by another problem.
All you need to do is keep the filter and outdoor coil clean, open the blower compartment and check the wheel for dirt buildup.
you can clock the gas meter to check the fuel input and check the temperature split in heating and cooling mode.
once's a system is properly set up you don't need someone year after year on such new equipment.
My Backround FIY: I am not in the business of any trade or topic I give advise on. I have some have formal education in HVAC + some DIY experience. Theory is not a substitute for experience.
user_12345a is online now   Reply With Quote
Old 06-03-2017, 02:44 PM   #29
Hvac Pro
yuri's Avatar
Rewards Points: 396
Not true.
The fin spacing on the secondary coil is very wide compared to the AC coil so the cooling coil catches dirt fast. Dirt can get on the cooling coil if the filter is not properly maintained but to say a secondary coil works like a filter is nonsense. FYI Carrier uses a plate secondary coil and it catches no dirt.
People invest $6000-$10000 or more in high end HVAC units and like to have maintenance done to catch the unit leaking freon ( if it does ) and have their drains checked etc.
Has nothing to do with the age of the unit.
Wilbits likes this.
Old 06-03-2017, 03:50 PM   #30
carrier dropped that design and went to finned stainless due to class action suite and lots of warranty claims, no?
main point being, if the filter is doing it's job, the coil should never have to be pulled in it's life. if the filter is letting dust through the blower wheel and secondary will be dirty as well to an extent, if they're clean the coil should be clean as well. if not maybe coil has dirt too.
likewise if the gas pressure, charge and airflow/fan speed were properly set at factory or in the field, no reason to get those checked year after year.
the owner can clock the gas meter and check temperature rise for heat and if it changes year after year know something is wrong.
likewise, for cooling the owner can check the split once a year with a inexpensive thermometer and even check wetbulb to take humidity into consideration.
If it's leaking "freon" the split will change and owner will know to make call.
it's a lot of money to have someone out every year.
if everything is working right and looks clean, kind of overkill to call someone every year to do a cleaning and checkup on something so new.
HELP!!! How much owe my HVAC repairman? Is he competant? MB1 HVAC 23 02-01-2012 02:42 PM
Lennox HVAC in Watchguard Mode (4+1) onefastwrex HVAC 19 01-10-2012 04:28 PM
Does this look like asbestos wrapping my HVAC register? htabbas HVAC 12 11-22-2011 06:15 AM
HVAC in out Condo Jzone99 HVAC 10 11-21-2009 04:28 AM
