No Access To HVAC Evaporator Coil - HVAC - DIY Chatroom Home Improvement Forum
Old 07-08-2013, 04:35 PM   #1
Rewards Points: 35
No access to HVAC Evaporator Coil
Hi,
I was trying to plan to clean the evaporator coil on my 10 year old furnace, but noticed that there is no access. There is sealed metal ducting. What is the best way to open this up? Does it require cutting the duct and putting an access sheet metal? What tool would be required to cut this thick duct?
Jay
jay235 is offline   Reply With Quote
Old 07-08-2013, 04:55 PM   #2
Rewards Points: 35
Here are some pics
Old 07-08-2013, 05:02 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
go to HDepot and buy a pair of sheet metal snips. one cuts left the other right. under $30. and a piece of sheet metal/ joist liner tin which you can buy there and some sheet metal screws and silver foil duct tape. yellow snips cut straight.
The Following User Says Thank You to yuri For This Useful Post:
TarheelTerp (07-08-2013)
Old 07-08-2013, 05:16 PM   #4
Rewards Points: 35
Which side would be best place to cut? Front where the copper lines are going in or on the back (other side of copper pipes?
Old 07-08-2013, 05:28 PM   #5
Hvac Pro
yuri's Avatar
whatever is easier. the coil is a ^ shape with the Freon going in the front and the ^ in that direction too. get 2 pieces of 12x12 tin as you may want to cut both sides. not easy or fun to get under that coil especially if it has cat/dog hair in it. if it is real dirty you should spray it with Simple Green cleaner and then flush it with clean water. Have fun.
jay235 (07-08-2013)
Old 07-08-2013, 05:35 PM   #6
Rewards Points: 6,652
Look on the oter sides. There should be a seam where they pushed the one panel on. Otherwise they would not have been able to place the A-coil on top, without doing a lot of magic tricks, to do so if it was placed inside that plenum to begin with.
Now of course there are some where the coil is inside a box, but even those have an access point on them.
Old 07-08-2013, 05:37 PM   #7
Rewards Points: 1,278
Some seemingly DIY jobs are best left for the professions and in my opinion this is one of those.
Old 07-08-2013, 06:05 PM   #8
HVAC Tech/Owner
Rewards Points: 604
Naw...he should go for it!
Technow is offline   Reply With Quote
Old 07-08-2013, 06:16 PM   #9
PoleCat's Avatar
Rewards Points: 1,646
I just did mine today and I haven't got a lick of sense. We have been here 20 years and have a whole mess of cats so I figured it was time. And it was too.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 07-08-2013, 08:13 PM   #10
Rewards Points: 35
Yeah, I don't mind cutting the sucker up and making a small access door. The next cleaning will be a lot easier.
Old 07-08-2013, 08:16 PM   #11
Why, I did mine when I had to open it up to put the A-Coil in my plenum. Of course it meant taking apart the whole upflow to remove the panel from the seam, but was able to do it, then put it all back together after done.
Yes there are some things that a homeowner may want to farm out, that either is beyond their abilities, or too costly to go out and rent or buy all of the tools needed, or have a time constraint that will cause them to call someone that can do it in 1/4 or 1/2 the time.
For example, I could have replaced the next door neighbor's Cast Iron Closet Flange, but that would have meant ordering the Fernco doughnut needed to replace the cast with PVC, since I cannot get it locally at any of the big box stores here in town, but could get it through a friend's mom who runs a supply house.
Then add in the time it would have taken me compared to just farming it out to a professional, who had the job done in two hours today for her, including putting the toilet in place and a new shut-off for her, while I was at the dr's office.
Old 07-08-2013, 08:50 PM   #12
Hvac Pro
yuri's Avatar
cleaning a coil is not Rocket Science. we are not talking about playing with gas lines or anything dangerous. buy a pair of those Mechanix cutproof work gloves (HDepot should have some) as sheet metal cuts like a knife.
gregzoll (07-08-2013)
Old 07-12-2013, 09:59 AM   #13
Originally Posted by jay235 View Post
You may also want to consider a safety shut off switch in the secondary condensation drain.
Methodical is offline   Reply With Quote
Old 07-12-2013, 10:04 AM   #14
Rewards Points: 35
You are correct. Right now it just has a red cap over the second opening.
Old 07-12-2013, 01:48 PM   #15
Lol
Sent from my iPhone using DIY Forum
ryandeen is offline   Reply With Quote
HELP!!! How much owe my HVAC repairman? Is he competant? MB1 HVAC 23 02-01-2012 02:42 PM
Lennox HVAC in Watchguard Mode (4+1) onefastwrex HVAC 19 01-10-2012 04:28 PM
Does this look like asbestos wrapping my HVAC register? htabbas HVAC 12 11-22-2011 06:15 AM
HVAC in out Condo Jzone99 HVAC 10 11-21-2009 04:28 AM
