No AC Last Night - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2015, 07:57 AM   #1
Rewards Points: 50
No AC last night
After a power outage yesterday, it appears that it took out one of my furnaces: Rheem Criterion II LXE model RGPL 10EBRMR
I noticed that the condenser was on for a long time and got to checking and no air discharge from the ducts. I shut the system down for 30 minutes and no luck upon turning it back on, the furnace is dead.
The unit does display 2 green lights, like my other that works, so I want to assume here it is the module in the ECM motor and not a main board?
Thoughts please?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 11-07-2015, 08:14 AM   #2
Rewards Points: 678
Well digital, no need to panic that's for sure. According to the National Weather Service it's looking as if you may not need anything except possibly a fan for awhile.So hopefully there is time to shop around for parts and repairs.
http://forecast.weather.gov/MapClick...7#.Vj31br_ZO1s
SeniorSitizen is offline   Reply With Quote
Old 11-07-2015, 08:26 AM   #3
Rewards Points: 50
Rain and humidity today, the wife is not pleased!
Old 11-07-2015, 10:22 AM   #4
Rewards Points: 50
Update
So I had an old motor and module from a previous similar event 6 years ago on the other unit. When this one went,I bought a whole new motor and module because I did not know modules or fixes were available.
On the first one, I bought the clearly blown/burned thermister and replaced it. So I took this repaired unit, installed it and BAM it works!
Great the wife is smiling!
Now for the followup: The removed module has no indications like the first one that was repaired,of any burned or blown electronics, but it is clearly the problem. SO my question is: How do I test the thermister since it is not indicating any burn marks on the board or bloat?
Old 11-07-2015, 10:29 AM   #5
An old Tradesmen
Rewards Points: 6,464
Clip the one end, and ohm it out.
The Following User Says Thank You to beenthere For This Useful Post:
digitalplumber (11-07-2015)
Old 11-08-2015, 09:08 PM   #6
Rewards Points: 50
Question:
Should I buy this newer replacement Genteq 51-104906-10 manufactured in 2014, which I found on a website that indicates it is a replacement for Protech 51-24383 80. Or should I buy an old stock but new protech manufactured in 2007?
Old 11-09-2015, 05:57 AM   #7
An old Tradesmen
Not sure it matters. Not real familiar with Rheem VS blowers though.
digitalplumber (11-09-2015)
Brightest LED night lights? With or without daylight sensor daluu Electrical 5 01-28-2015 01:39 PM
Night time heating with space heater beengone HVAC 21 09-24-2012 06:39 PM
Got to see Joe Walsh last night JulieMor Off Topic 7 07-15-2012 10:22 AM
furnace blower won't turn on at night. mariamav3 HVAC 9 02-16-2012 08:54 PM
