No 24 Volts Carrier Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 02:09 PM   #1
no 24 volts carrier furnace
I have no 24 volts for my humidifier
mrlacroft is offline   Reply With Quote
Old 01-30-2012, 02:25 PM   #2
Where are you checking on furnace and what reading are you getting.
Some Carriers are 24 v others are 110 v.
Does the furnace still run on a call for heat?
hvac5646 is offline   Reply With Quote
Old 01-30-2012, 04:44 PM   #3
how
Rewards Points: 1,104
HVAC5456
Does the humidifyer board pin only get powered when the fan is running on Carrier boards?
how is offline   Reply With Quote
Old 01-30-2012, 05:01 PM   #4
Ha! I don't remember if it's the inducer or the blower.
Got a bad case of CRS to day.
Old 01-31-2012, 09:35 AM   #5
yes
yes the furance does work ok. I am getting no voltage at the conector that says humidifier.
Old 01-31-2012, 09:59 AM   #6
either you are not getting a good hot to neutral reading or your board is shot.
Old 01-31-2012, 10:12 AM   #7
that terminal will only be hot during a call for heat
harleyrider is offline   Reply With Quote
Old 01-31-2012, 10:14 AM   #8
dst's right.
What are the carrier furnace codes? porang HVAC 1 01-24-2011 07:45 PM
Carrier Furnace bmak3 HVAC 1 01-13-2011 06:43 PM
Carrier furnace problems BigK75 HVAC 1 07-30-2009 05:16 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
My Carrier furnace is driving me crazy hifiuser HVAC 6 02-10-2007 09:48 AM
