Nitrogen - HVAC - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 02:26 PM   #1
Rewards Points: 85
Nitrogen
Hello,
What sort of connectors does one use to flow nitrogen through tubing while brazing? It seems that Nitrogen uses the same bottles and regulators as Argon etc ( CGA580 IIRC ). For leak checking, I'm thinking a hose with a schraeder fitting to screw into the service port. But it would need to be a good one - I really don't want the whole thing coming apart at 150PSI.
For brazing: If I already had such a hose in hand, I'm thinking that a couple of tubing couplings with a schraeder brazed to the end - one 1/8" and one 3/4" - would do the job. Not much pressure involved, just flow.
Comments?
- JerryK
jerryk1234 is offline   Reply With Quote
Old 08-17-2011, 08:37 PM   #2
An old Tradesmen
Rewards Points: 6,590
Just use your charging hoses. Connect one side up, remove schrader of the opposite line, flow a little nitrogen, and braze. Inspect joint/joints. Repeat for opposite line.
Old 08-17-2011, 09:53 PM   #3
For really good results you can assemble your piping, put the vacuum pump on it for a couple of minutes and then fill the system up to 1 or 2 psi with nitrogen and just keep the valve slightly open to keep positive pressure on the system. Braze the condenser fittings last as you will need to turn the valve off when doing the last joint.
Make sure you test with pressure. Speaking from experience, you can vacuum down a system with an unbrazed fitting. (Wow..that lady was pissed off mad..)
Don't vent any pressure through the vacuum pump as the oil tends to become airborne when that happens..(another pissed off lady).
Master of Cold is offline   Reply With Quote
Purgin with argon vs nitrogen hartkem HVAC 2 08-08-2010 12:16 AM
had soil tested...need to add .7 pds of nitrogen per 1,000sqft jongordo8 Landscaping & Lawn Care 1 04-08-2010 07:40 PM
difference between pH, fertilizer and nitrogen? windowguy Landscaping & Lawn Care 5 07-29-2009 11:19 AM
leaking freon - nitrogen ? wetbar HVAC 9 07-01-2009 01:42 AM
question on fertilization rates joeyboy Landscaping & Lawn Care 6 05-05-2008 04:47 PM
