Ng Furnace Won't Turn Off - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 07:44 PM   #46
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
We always put them on the cold air return. Older furnaces run a LOT hotter supply air temp (up to 150 and over degrees F) but your new one may go up to 130-135 so it is not cool either. Should not go on the hot air duct ever IMO.
Old 12-16-2010, 08:21 PM   #47
cowboy dan's Avatar
see, i learned something already.... mine is set to 120 for stage l and 140 for stage ll. my new humi is on the cold side. i would have thought that a hot humi would be made of somthing other than plastic. i also heard that the manuals say they can be on both. with that in mind, maybe i should go after the manufacturer for the misleading info.
cowboy dan is offline   Reply With Quote
Old 12-17-2010, 01:37 AM   #48
I don't know of any mfg that doesn't allow supply or cold air mountings
Most of us have gone thru a humidifier over flow in our careers. And if it was a supply side mounting water ran allover the furnace controls and damged them.
That is the biggest reason I use the cold air return.
hvaclover is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 03:22 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Furnace w Cooling unit wont turn off Klatimer HVAC 2 09-19-2008 08:35 PM
