Ng Furnace Won't Turn Off - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 12:04 AM   #16
cowboy dan's Avatar
totally awsome! yeah, it cost $5100, but the humi was cracked and not fixable. who ever installed it put it on the hot side and as a result, the housing melted. it has been replaced relocated to the cold side. i have a ton of pics of the furnace install but i'm not sure if i would post them, not sure if name dropping is permited. i feel like i got what i payed for. i was treated with respect, he explained everything to me as i was his shadow for the whole thing. i think differently now having a solid, quiet unit. he explained how the 2 stage system worked. it maxes out at 70,000btu. it will normally run on the low stage all the time. it is set to cycle after 1 deg drop. the high stage kicks in only when needed. i have the a/c power and he would have chosen a d/c motor over the a/c. as for craftmanship, truley topshelf! the most interesting part was the core drilling. that was 2 minutes of awsomeness! the worst part was the pvc glue for the exaust... i still have a headache. the other glue that his partner used on the pump smelled like a 4:20 safety meeting. 22c, no c0, cbd= happy!
cowboy dan is offline   Reply With Quote
Old 12-16-2010, 02:44 AM   #17
Post them!!!
We all like to hear when a job goes well for a homeowner and that you were happy with the way you were treated. Makes both HO an pro happy to read a success story.
Now post them pics cause you got me wanting to see a good clean install.
Post all of them!! Yuri and Benthere would be very disappointed if they missed seeing them.
hvaclover is offline   Reply With Quote
Old 12-16-2010, 07:08 AM   #18
cowboy dan's Avatar
Originally Posted by hvaclover View Post
Post them!!!
lol. i will when i get home. i am just warming the van right now. but i will then
Old 12-16-2010, 07:11 AM   #19
Hvac Pro
yuri's Avatar
Rewards Points: 1,420
You can post the installers co. name I believe. Unless it is your co. and you try sell your own goods that is verbotten. May help someone else in Calgary find a good installer.
Old 12-16-2010, 06:49 PM   #20
cowboy dan's Avatar
here are some. but i max out at 6 per. i'll just have to post more...lol
ng furnace won't turn off-furnace-install-dec-15-2010-002.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-001.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-004.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-005.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-006.jpg
Old 12-16-2010, 06:52 PM   #21
Hvac Pro
yuri's Avatar
Yer lucky to be alive with what happened to the old beast.
Old 12-16-2010, 06:55 PM   #22
cowboy dan's Avatar
a few more...
ng furnace won't turn off-furnace-install-dec-15-2010-008.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-009.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-010.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-011.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-012.jpg
Old 12-16-2010, 06:58 PM   #23
cowboy dan's Avatar
and more...
ng furnace won't turn off-furnace-install-dec-15-2010-014.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-015.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-016.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-017.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-018.jpg
Old 12-16-2010, 07:00 PM   #24
Hvac Pro
yuri's Avatar
The guy MUST be a Pro if he has proper power shears and doesn't just hack a hole with a hammer and slotted screwdriver ( can opener) method.
Old 12-16-2010, 07:11 PM   #25
cowboy dan's Avatar
lol, they did use the screwdriver but i had put my camera down and couldn't find it. but they only did that to start in, then he zipped it. this is where it got interesting. this young guy showed up for the core cut, this was the best i could do, he was here and gone in under 10 min...lol fastest, most awsome show of skill! i should have taken video but...
ng furnace won't turn off-furnace-install-dec-15-2010-020.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-021.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-022.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-023.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-024.jpg
Old 12-16-2010, 07:14 PM   #26
Danm Dan! There were flames coming out the front of the old one!
I like the one of the old furnace in front of the house....looks like a dead body of a burglar who got shot fleeing the scene of the crime lololol
Old 12-16-2010, 07:15 PM   #27
cowboy dan's Avatar
this was the coolest tool of the day
ng furnace won't turn off-furnace-install-dec-15-2010-026.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-027.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-028.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-029.jpg   ng furnace won't turn off-furnace-install-dec-15-2010-030.jpg
Old 12-16-2010, 07:22 PM   #28
cowboy dan's Avatar
this is the finished install. total labour= 8hrs.
ng furnace won't turn off-001.jpg   ng furnace won't turn off-002.jpg   ng furnace won't turn off-003.jpg   ng furnace won't turn off-004.jpg   ng furnace won't turn off-005.jpg
Old 12-16-2010, 07:23 PM   #29
Hvac Pro
yuri's Avatar
Boy the guy REALLY must be a Pro if he owns one of those fancy UEI/Testo thing a ma jiggers.
With a concentric vent kit like you have you need to once a year check the intake hood outside for debris/spider webs and make sure no snow builds up near it and gets sucked in.
VERY nice job, most guys SLAM them in in 4 hrs and get paid piece work. I would throttle the damper on the humidifier half way closed, you don't really need HIGH velocity air flowing thru it. Mine is 1/2 closed and builds up more airflow upstairs rather than losing pressure and I can easily keep my RH at 30-35%.
Old 12-16-2010, 07:26 PM   #30
cowboy dan's Avatar
lots of new stuff. i like the clean repairs to my old duct work. the last pic was a mod just for me, cause i'm ... me. just to access the filter.
ng furnace won't turn off-007.jpg   ng furnace won't turn off-008.jpg   ng furnace won't turn off-010.jpg   ng furnace won't turn off-009.jpg   ng furnace won't turn off-011.jpg
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Comfortmaker furnace won't turn on steelframe8459 HVAC 36 11-30-2011 04:22 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Furnace w Cooling unit wont turn off Klatimer HVAC 2 09-19-2008 09:35 PM
