Newbie Stumped By Simple Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 07:26 PM   #1
JPM
Bill Traver
Rewards Points: 101
Newbie stumped by simple thermostat
I have a basic, very old floor unit that was not working...I changed out the gas valve and things seemed to be okay with one exception... The thermostat was not working. I replace it with simple heat only circular one and it still does not work ... It's only r and w ... When I remove thermo and tie them together, the gas valve triggers!!!! What's going on here with not getting the thermostat to work(ps, I made sure the switches were set proper too)
Thanks for any advice
JPM is offline   Reply With Quote
Old 12-05-2010, 07:54 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 136
Probably has a millivolt burner/works off less than 1 volt thru a powerpile self generator. Too much resistance in the heat anticipator of the thermostat. A GOOD quality Honeywell Focus Pro tstat may work with your unit as it is an electronic type with good quality low resistance switches and no heat anticipator. An el cheapo won't work well. Get it at HDepot.
The Following User Says Thank You to yuri For This Useful Post:
JPM (12-05-2010)
Old 12-05-2010, 08:39 PM   #3
Rewards Points: 6,652
If still wanting the basic type thermostat, either electronic, or manual, look on the packaging, and it will state what type of systems it will work with (mili-volt, 24v, etc).
Newbie question - thermostat functioning and baseboard heaters keith-k HVAC 2 10-26-2010 09:20 AM
connecting a 4 wire SP thermostat to a 2 wire system wiichkin Electrical 4 08-15-2010 01:35 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
