Newbie Question, Mastic Or Aluminum Tape For Leaks? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2016, 12:44 PM   #1
Rewards Points: 376
Newbie Question, Mastic or Aluminum Tape for leaks?
I'm sure this question has been hashed out before.
I am noticing some leaks within my HVAC duct system in my attic.
My inspection report noticed a plenum leak as well.
I would like to seal some of this up.
In your opinion, does the alum tape or mastic work better?
Also, what's the best kind to get?
I've heard that Home Depot and Lowe's sells not so good stuff.
Thanks!
Alumifab is offline   Reply With Quote
Old 01-25-2016, 05:48 PM   #2
An old Tradesmen
Rewards Points: 7,776
Mastic is best.
Old 01-25-2016, 06:37 PM   #3
Rewards Points: 4,080
If they're small simple leaks then I would go with tape (faster and cleaner). If it's a mess of leaks then the mastic would be better.
Bob Sanders is offline   Reply With Quote
Old 01-25-2016, 06:54 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Ayuh,.... 'n that's what I always thought Duct tape was for,.....
Bondo is online now   Reply With Quote
Old 01-25-2016, 09:24 PM   #5
Rewards Points: 386
Use both, whichever is most convenient. If you are working blind in spots you have to use the aluminum tape, like if you are sealing a 10" pipe already tight up in a joist bay. Junctions where pipe runs into plenum boxes are best done with mastic.
HD/Lowes sells two qualities of aluminum tape, the small paper-thin crap and the thicker good stuff with code writing on it.
ChuckF. is offline   Reply With Quote
Old 01-25-2016, 09:38 PM   #6
Rewards Points: 46
For us, it depends on what was written on the drawings. Sometimes we have to use tape, then duct sealant over it. (like mastic but dries rock hard in no time, with minimal smell)
99% of our ductwork is in conditioned space. Therefore we generally don't worry about it unless the engineer demands it.
Cheers!
supers05 is offline   Reply With Quote
Mastic vs foil tape drew53813 HVAC 26 07-27-2015 07:03 AM
sealant question - in the long 1 and 1/2 ft thin aluminum "sausage " type container hidden1 General DIY Discussions 11 10-24-2012 06:43 PM
Repairing a few leaks on start collar - Foil Tape or Mastic? Hogan773 HVAC 7 08-25-2012 09:55 AM
Newbie question about crack in PVC joint LinusInPW Plumbing 8 11-16-2007 11:25 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
