Newbie HVAC Troubleshooting - HVAC - DIY Chatroom Home Improvement Forum
Old 06-22-2009, 06:41 PM   #1
newbie HVAC troubleshooting
I am a newbie and have had an A/C installed about 2 years ago. Its a trane xl14i. I have recently noticed that the air pulsed in the rooms is not cold. The thermostat is functioning properly and switch on/off the unit adequately.
After having the unit running for a while, I would expect the tube (covered with foam) that connect the outside heatpump to the house to be extremely cold. It is not the case at all.
I would appreciate some help on troubleshooting the issue.
Eric
elm66 is offline   Reply With Quote
Old 06-22-2009, 08:38 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
The large line in that insulated tube should be cold and sweating at the outdoor unit. It may be low on freon and you should call the installer or a tech. Running low on freon can damage the unit. Part of the repair may be under warranty.
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 01:43 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
HVAC Upgrade Questions JonC HVAC 8 02-27-2009 05:04 PM
HEIL 5000 HVAC troubleshooting tidejunky HVAC 15 03-02-2008 04:19 PM
