Newbie Has Issues With Trane XE80 - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-09-2011, 10:06 PM   #16
Thanks a lot for your vote of confidence Ben. I am planning to call a pro out on Monday so I can see what they say before I run this unit full time. I meant what I said earlier I would not have gotten this far without you guys and I certainly appreciate what you all have done for me.
Thanks A Lot
Cary Hayes
hayescary is offline   Reply With Quote
The Following User Says Thank You to hayescary For This Useful Post:
Doc Holliday (12-09-2011)
Old 12-09-2011, 10:19 PM   #17
I'm Your Huckleberry
Rewards Points: 2,270
When you lit it up finally the inducer worked?
Doc Holliday is offline   Reply With Quote
Old 12-09-2011, 10:23 PM   #18
Id housing and flue pipe supposed to be hot, like car muffler.
Old 12-09-2011, 10:32 PM   #19
what can i say? again i have to apologies for not reading throughly........i missed the post were you said that the ID motor was running
harleyrider is offline   Reply With Quote
Old 12-10-2011, 06:52 AM   #20
The inducer did work when I lit it up. I believe that everything is working as it should be. I am not very experienced with what a normal heat cycle is like with one of these units.
So far I have only ran this unit for one complete heat cycle and I observed the following. The inducer powered up first running in its own briefly, something then began to glow near where the burners are, the burners lit and heated the heat chamber for a little bit before the blower motor came on.
During the power off process I did not pay as much attention as I did with the startup process, but I think the inducer shut down prior to the burner turning off. Not sure if this is normal or not??? I did notice when the burner shut down the blower still ran for a minute our two.
Can you guys tell me if what I am experiencing here is normal our not with regard too a typical heat cycle?
Old 12-10-2011, 09:04 AM   #21
yes that sounds like a perfect cycle.
The Following User Says Thank You to harleyrider For This Useful Post:
hayescary (12-10-2011)
Old 12-10-2011, 10:28 AM   #22
thanks a bunch guys, I am going to leave the rest up to the heat and air guys.
Cary
Old 12-10-2011, 11:11 AM   #23
jkv
Hey Harleyrider, don't know what your problem is but you need to figure it out and deal with it instead of being ignorant with everyone that is just asking for help. That is what this forum is all about, you think you know eveything and news flash YOU DON'T, yea I may be simple in my words on here but I am a HVAC tech. and I do know what I am doing sometimes it is better to start with the most simple and work to the most difficult and to put in the way they can understand it. Your words can build one up or tear one down your choice.
jkv is offline   Reply With Quote
The Following User Says Thank You to jkv For This Useful Post:
Doc Holliday (12-10-2011)
Old 12-10-2011, 12:46 PM   #24
I have to agree.
Harley, quit the BS.
Old 12-10-2011, 02:29 PM   #25
I don't really care what you think of me....well I do, but I hate redundancy. If someone clearly describes a problem and the problem is evident from that explanation then why lead a person with limited knowledge down a long as confusing path?
if you turn on a light switch and the light does not come on, do you remove the cover from the electrical panel and inspect the breaker.......or do you swap out a light bulb?
Old 12-10-2011, 06:16 PM   #26
Harley, everyone will not think the same or be on your train of thought so unless your goal is complete world domination you need to let people be. Please just try and not fight or pick at people. The only one who ends up looking small is you.
Old 12-11-2011, 10:46 AM   #27
Hey Harley, In my opinion and from the standpoint of a Newbie any information provided no matter how redundant it may be is much appreciated and valuable to someone like myself who has no knowledge of HVAC. I would like to think that most of the people who are DIY'ers and posting on here have a least some bacis knowledge of how things work and I would hope they know their way around a toolbox.
For instance I have no knowledge of construction, electrical, plumbing, HVAC, etc..., however I have managed to completely gut and rebuild a 2500 sqft. home. I was able to do this with the help of people like yourselves, who are kind enough to lend some of their knowledge to the less fortunate like myself. I was also able to dothis because I believe that I know generally how things work and are supposed to be done, but believe when I came to a point where I did not know I would always consult with more knowledgable individuals such as yourselves.
Just like with this post several people responded to my original post and the responses varied some so I read everything decided what I could do within the scope of my abilities and got to work teching out the problem and finding a solution.
At the end of the day, redundant or not, all information above what a person already knows, should be consideered as valuable.
Thanks again for everything guys, I am sure I will be calling on you again in a few months when it comes time to install the airconditioning portion of my used HVAC equipment and I hope that it goes as smoothly as this job did.
Cary
Trane XE80 Furnace fan won't stop running Luv2Auction HVAC 2 01-07-2013 10:05 AM
Trane xe80 no heat tackman HVAC 9 11-05-2010 02:33 PM
Trane XE80 - No ignition ggutier49 HVAC 3 10-17-2009 10:38 PM
Twinned Trane XE80 issues pconrad HVAC 7 12-09-2008 12:26 PM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 07:34 PM
