Newbie - HVAC - DIY Chatroom Home Improvement Forum
Old 12-20-2009, 12:19 PM   #1
Alexander
I have a high efficiency furnace (tempstar) installed in an older (1972) ome and wonder if i can use the combustion air vent for the fesh air intake? Also, since installing the new furnace and finishing the basement the current fresh iar intake vent has been frosting and drippng into the basement rooms. If i need the fresh air intake how do i stop it from frosting and dripping??
Alexander is offline   Reply With Quote
Old 12-20-2009, 12:48 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
You have 2 plastic pipes, 1 for combustion air and the other for exhaust and they MUST be left alone. You can insulate the combustion air pipe with pipe wrap if it sweats. The old 5-6" combustion air pipe may be needed for the gas water heater if you have one. If not you can convert it to a fresh air pipe to the return duct and put a damper in it. I recommend a motorized Hoyme damper to allow the air thru it only when the heat is on. Post some pics of what you have. Where do you live?
Old 12-20-2009, 12:54 PM   #3
You want to connect the exhaust vent to the air input ?
That would be like connecting the exhaust of your car to the air filter input
Not a good idea
Newbie needs help in wiring humidifier. gm2685 HVAC 3 11-14-2009 12:40 AM
SW Ohio Newbie JACC0811 Introductions 2 03-22-2009 03:37 PM
15 year old deck, newbie, ouch! Theron D Painting 7 08-25-2008 11:05 AM
Newbie question about crack in PVC joint LinusInPW Plumbing 8 11-17-2007 12:25 AM
can a newbie finish a basement... konboy Building & Construction 73 04-11-2007 07:11 PM
