New Yorker Boiler Model # FR-122-W - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2010, 11:59 AM   #1
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
Ok so right now we have no heat to the second floor. Circulator pump is running. There is hot water and the furnace is firing as it should be. The hot water pipes up to the second floor are cold even with the circulator pump running. We tried to bleed the air from the system but no air or water came out. First floor has heat. It seems as though the system is not filling. My brother took three years of HVAC at a tech school during high school and he has no clue. This system was installed sometime in the 80s I think. If you want I can get you pics but it would have to wait until tomorrow. Thank you in advance for your time.
There is no such thing as a stupid question, but there is such a thing as an ignorant person, with a question, trying to learn.
Pudge565 is offline   Reply With Quote
Old 02-07-2010, 12:46 PM   #2
JohnH1's Avatar
Low water pressure
JohnH1 is offline   Reply With Quote
Old 02-07-2010, 06:45 PM   #3
An old Tradesmen
Rewards Points: 7,816
Yep, low water pressure.
Does your system have a manual bypass you can use to add water to the boiler.
Need to replace the autofill if it isn't working.
PS: Check to make sure the manual valve before the autofill is open.
Old 02-07-2010, 07:46 PM   #4
Pudge565's Avatar
Rewards Points: 150
Ok thanks for the replies. I am not sure if it has a manual bypass, I am pretty sure that it does not. What does the autofill thing look like? I think I know what it is but I'm not sure and can't seem to find a picture of one.
Old 02-07-2010, 07:52 PM   #5
An old Tradesmen
Depends if its a B&G or Watts or Taco.
It will be on your cold water line to the boiler. Probably have a lever on it that flips up or a thumb screw to turn in to add water manually.
Can you take pics of your boiler and post them.
Old 02-08-2010, 01:29 PM   #6
Pudge565's Avatar
Rewards Points: 150
Yes I can take pictures and post them today. I will do so as soon as i get home.
Old 02-08-2010, 04:54 PM   #7
Pudge565's Avatar
Rewards Points: 150
Ok here are some pictures.
This one is what I think is the auto fill valve:
This is a pic of the plumbing for the inlet:
Here is the expansion tank:
Thoughts and opinions appreciated.
Old 02-08-2010, 05:12 PM   #8
An old Tradesmen
Ok.
The green device in the first pic is your auto waterfeed and relief valve set up.
The plug in the relief valve is a bomb waiting to go off.
You'll need to replace that whole assembly. And then pipe the relief to within 6" of the floor.
Your water is leaking out your circ's top flange gasket, that needs replaced.
The hand valve on the right, just above the circ, may be a manual feed. Can't tell from here.
Fix those other things before you have a catastrophic failure, that harms you or others.
Old 02-08-2010, 05:40 PM   #9
Pudge565's Avatar
Rewards Points: 150
Originally Posted by beenthere View Post
Ok.
Ok thank you. No that valve just shuts off the flow to the overflow tank; which, is very old and not the newer bladder type. Unfourtunatley we are on a tight budget right now. Would the water feed and relief vavle be available at either HD or Lowe's? I cringe at the idea of buying from them but well I guess we will have to. Also the circ pump has been like that for awhile. Is fixing the flange an easy fix? And when I was looking at the circ pump while taking pics it looks like it is accually leaking from a small hole on the bottom side of the circ pump. That is not the worst part though. Last time my brother fixed this unit (the gasket around the water coil went bad) he half ass made a new gasket and it still leaked so he just JB welded around it. I yelled at him for that one. I will fix it myself then I know it will get done right.
Old 02-08-2010, 06:01 PM   #10
An old Tradesmen
Doubt HD or Lowes will have them. But neve hurts to check.
Spring may not have enough tension on circ. Or, the bearing assembly is worn out. If its worn out, you want to replace it before it lets loose and you have no heat on any floor.
I wouldn't let your brother touch my water heater, let alone boiler. If he does that kind of work(not meant to be rude, just honest).
Old 02-08-2010, 06:02 PM   #11
An old Tradesmen
You need those leaks fixed. Or the fresh water always being added will KILL your boiler. Which won't be cheap to replace.
Old 02-08-2010, 06:45 PM   #12
Pudge565's Avatar
Rewards Points: 150
Oh trust me I am with you. But it is not my boiler it is my parents ( I do live there.) I think I know more about this stuff than he does as when I asked him what the green things were and what they did he said he didn't know. He also tried to tell me the circ pump was bad when I heard it running and pushing water. Also what would cause the pressure relief vavle to leak while the unit runs? It is a slow steady stream. The vavle was replaced about a year and a half ago when the burner motor was replaced. It may be the temp settings (not set by my brother) which are set at 160F and 180F low and high respectivley. They were set by the last service tech about 5 years ago. The unit since then has only been cleaned and serviced by my brother.
Old 02-08-2010, 06:59 PM   #13
An old Tradesmen
Expansion tank is probably full. And until now. Everytime the burner ran and brought the water temp up. The pressure went to 30PSIG and the relief valve did its job. And now its seat is worn out, scared, or dirt is in it.
Old 02-08-2010, 08:18 PM   #14
Pudge565's Avatar
Rewards Points: 150
Ok so are those temp settings normal?
Old 02-09-2010, 12:57 AM   #15
An old Tradesmen
Yes. Those are normal settings for a boiler with tankless hot water coil.
The New Yorker CGS-A Series Boiler Leodin HVAC 2 01-18-2010 06:48 AM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 08:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
New Boiler - Not sure what model to buy??? art2670 HVAC 2 05-11-2007 11:30 PM
Sub Switched Weil-McClain boiler model Dragon HVAC 2 01-24-2007 03:35 PM
