Old 12-25-2011, 03:19 PM   #1
new wall heater no longer works
I have a new williams wall heater, it worked for two weeks, it now does not turn on, the pilot is on. Is it a bad sensor.
motomx is offline   Reply With Quote
Old 12-25-2011, 07:42 PM   #2
MarginallyQualified
it worked for two weeks, it now does not turn on...
These heaters aren't real complicated. But being new, the "usual suspects"
should be covered by warranty including labor.
I'd be calling the shop you bought it from.
hth
Old 12-26-2011, 08:33 AM   #3
biggles's Avatar
remove the stat and jump the 2 wires within...nothing something bad stat.....find the wires within the furnace from the stat and put them together... nothing something wire from stat is broken/open..call the installer
Wall Heater Disconnect seansy59 Electrical 2 11-06-2011 07:35 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
A glue that works on precast concrete wall wildwings Building & Construction 5 12-30-2010 09:34 AM
Correct gauge wire on wall heater?? Master Brian Electrical 4 11-16-2010 02:48 PM
Cadet wall heater Jack E HVAC 1 04-21-2010 05:55 PM
