New (used) Garage Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2008, 08:31 PM   #1
new (used) garage furnace
I just installed a used furnace I had given to me. It's a Miller residential natural gas forced air furnace. The model is G3RC080C-16 and the year is 1993. My old furnace was 15years old 20 years ago when I installed it, so it needed replacing. However, I don't know anything about this furnace. My old one was pretty simple. First, I have a problem with it. When I first installed it, about 6 weeks ago, right from the start it would come on, the burners would fire and the fan would come on. After it ran for maybe 2 to 3 min, the fan would cycle on and off very rapidly, then stay off for 30 to 60 seconds then come back on till the furnace shut down. This last weekend we got -35 below wind chill and i went into the shop and the face where thr eye is was all frosted up, the exhaust blower(?) was running continually, but the burners wouldn't fire. The igniter wasn't coming on, so I got a new igniter, but it still won't fire. Any ideas? Thanks.
coldnorth is offline   Reply With Quote
Old 12-19-2008, 10:05 PM   #2
Make sure the vent isnt buried in snow.
SKIP4661 is offline   Reply With Quote
Old 12-20-2008, 07:48 AM   #3
An old Tradesmen
Rewards Points: 6,112
Yep, check your intake and vent pipe.
Old 12-22-2008, 11:09 AM   #4
Vent pipes are 4' above snow. Where else can I look to get it to fire. Vent fan comes on, igniter won't light.
Old 12-22-2008, 11:42 AM   #5
Would the limit switch have anything to do with the furnace not coming on and is there any way to test the gas valve? Except for the cycling issue, the furnace worked until it frosted up. I took apart the vent and exhaust at the furnace and nothing. I know it worked this way before when I was testing it when it was first installed.
Old 12-22-2008, 12:29 PM   #6
An old Tradesmen
Did you check to see if the ignitor is bad.
Ignitors and limits can be checked with a multimeter.
Old 12-27-2008, 10:26 AM   #7
The reset button was bad. It lights, but now the blower fan won't come on. I can only look thru the front of the furnace and I can't see a reset on the motor. Is there a reset for the blower also.
As stated in my original post, I did replace the igniter first.
Old 12-27-2008, 11:39 AM   #8
An old Tradesmen
The blower motor has an internal auto reset overload.
What reset did you replace.
Old 12-30-2008, 05:27 PM   #9
the switch on the exhaust motor.
I'm going to try to get a friend over to test the motor, but maybe the capacitor? The blower fan worked before this all happened. Now everything else seems to work but the blower.
Old 12-30-2008, 05:30 PM   #10
An old Tradesmen
Thats more of a clogged vent switch.
Old 12-31-2008, 07:33 PM   #11
Any thoughts on the blower motor? Capacitor?
Old 12-31-2008, 09:19 PM   #12
An old Tradesmen
Possible.
But, without checking it with a meter, can't say from here.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
trailer furnace on blocks in garage creek1369 HVAC 4 12-17-2008 07:18 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
garage furnace mrseebro HVAC 3 01-07-2008 08:25 AM
