New Tstats: Residential Carrier Weathermaker II Two-Zone Comfort Zoning System - HVAC - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 08:28 PM   #1
New tstats: residential Carrier Weathermaker II Two-Zone Comfort Zoning System
Current heat pump model number: TCH430AKA1 Sears (OEM = Tempstar?)
Current thermostat model number: P274-0100 Totaline
(there is one upstairs and one downstairs for 2-zone system)
tstat Zone 1 has G, Y1, R, W1 and C wired.
tstat Zone 2 has Y1, R, W1 and C wired.
Current control box: Carrier Weathermaker II Two-Zone Comfort Zoning System
control box has RC, O, Y1, W1, G and RH wired. RC is jumpered to RH.
control box is about 10 years old.
Would like to change thermostats to something programmable.
What models would you recommend?
I am confused by the lack of W2 connections, since this is a 2-stage heat pump with typical fan coils/heat strips.
JeanThomas is offline   Reply With Quote
Old 03-24-2011, 06:59 AM   #2
Better visuals:
share.shutterfly.com/action/welcome?sid=0AasXDlk5cM2LCJg
share.shutterfly.com/action/welcome?sid=0AasXDlk5cM2LCQA
share.shutterfly.com/action/welcome?sid=0AasXDlk5cM2LCYg
share.shutterfly.com/action/welcome?sid=0AasXDlk5cM2LCjA
share.shutterfly.com/action/welcome?sid=0AasXDlk5cM2LCrg
I think that everytime the tstats call for heat, BOTH the heat pump compressor and the heat strips are activated!
Can anyone confirm this?
Old 03-24-2011, 10:22 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
your zone board is controlling the output, your input is a standard input for a conventional system and then the zone board deciphers from there what part of the system to use. if you call for heat from one zone. you can check the output of the board for 24v between C and G, Y1. If you have 24V between W1 and C while having the other 24V outputs then, yes, there is a problem.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Zone system retrofit possible? perpetualjon HVAC 2 07-14-2010 06:23 PM
Adding new zone makapacs HVAC 0 11-26-2009 01:35 PM
Replacing Heat Pump system - Carrier or Rheem? CoolMan74 HVAC 6 06-28-2009 11:13 AM
Zoning With Carrier Infinity Furnace ddartmouth HVAC 1 01-05-2009 12:55 PM
Zone system not working with heat. deliriousga HVAC 5 12-29-2006 07:04 PM
