Old 06-14-2012, 05:41 AM   #61
An old Tradesmen
New Thermostat Wiring issue
Look for a float switch in the secondary drain pan if you have a secondary drain pan.
In the pic in post #14 it shows a white wire on the R terminal of the air handler. So good chance if you trace that wire, it goes to a float/water switch of some sort. And that switch is probably doing its job. Fix water problem, and switch should lose.
Old 06-14-2012, 08:27 AM   #62
I'm Your Huckleberry
Originally Posted by aeroknight06 View Post
So if I'm reading this properly, you suggest removing the wires that go to the stat from the terminal block within the air handler and then checking the continuity with the ohm readings of a multi meter between the wires that were just removed at the stat. Since the wires are removed and if they are not damaged I should get 0 ohms, however if i get a reading i should then one of those two wires is broken. I would then move onto another wire to see if i got a reading to find out which of the previous 2 wires is the broken wire.
The opposite, actually, If there is a reading than the wires are good. Hopefully you have a digital meter that beeps when there IS continuity when you ohm. If there is no continuity then the meter should read OL for Open Line and will not beep, if it's digital.
It won't read 0 if there isn't any continuity, it'll read OL. Again, if digital.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 06-14-2012, 08:48 AM   #63
On the left would be the air handler, on the right the thermostat where you'd be using your meter.
No continuity/OL. Note the two wires on the left not touching.
1.1 resistance/wires connected on the left.
And this meter has a continuity setting which lights up a button as well as beeps when their is continuity without being on an ohms setting. When in this mode it does not show resistance so it does show 0 at all times. Again, wires connected at the air handler, the left.
Thanks.
Old 06-14-2012, 08:13 PM   #64
There is water on a drain to the right and a gray switch is raised I assume i have to clear the water from the drain pipe and then the unit should activate from what was posted a few ago. I'll try with a wet/dry vac and see what I get.
aeroknight06 is offline   Reply With Quote
Old 06-14-2012, 08:31 PM   #65
Can you simply lift the switch out of the pan? Or push the float part down for a few seconds while the system is on call for cool?
This way you'll at least know if the system works or not, if this is the problem.
Thanks.
Old 06-14-2012, 09:15 PM   #66
I can & I just did and the unit comes on. Removed the switch and turned on power and it works, appears like there is just some water in the line. I have a wet/dry vac that I'll use on the line from the outside. That's what the guy at Lowes suggested. Thank you everybody for the help. It appears that the thermostat was never the issue, I just went in assuming it was an electrical issue with the stat and not a safety trip for the unit. Well learned some new stuff and will check the drain valve next time. Thanks again.
Old 06-14-2012, 11:50 PM   #67
5 pages for a float switch, gotta love it!!
Glad you figured it out.
Thanks.
Old 06-15-2012, 05:30 AM   #68
An old Tradesmen
Your love thread kept you distracted.
Old 06-15-2012, 08:35 AM   #69
Someone mentioned a float switch a few pages ago but it was ignored until you said it.
Thanks.
Old 06-15-2012, 03:00 PM   #70
An old Tradesmen
I don't think the OP knew what TT meant by over flow switch.
Old 06-15-2012, 04:14 PM   #71
Apparently not. Btw, "Toptechnician is a handle used by several of us here, but now seeing it online it sounds a little arrogant; no?
We considered "donethat" but that would have just been too funny.
TopTechnician is offline   Reply With Quote
Old 06-17-2012, 11:56 PM   #72
Yea this operator doesn't know squat when it comes to AC units besides how to turn them on, though I did learn some more here recently. Sorry for wasting everyone's time for such a simple issue that I should have known about. But thanks for the help.
Old 06-18-2012, 05:07 AM   #73
An old Tradesmen
OP=Original Poster.
Sometimes we forget the terminology we use, is not known to the people we are responding to.
Thermostat issue, need help JonMio Electrical 1 02-10-2012 04:40 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Thermostat wiring Problem TRC Electrical 2 09-23-2010 08:37 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Thermostat wiring question cpuken HVAC 4 12-14-2009 08:32 PM
