Old 06-13-2012, 07:36 PM   #16
New Thermostat Wiring issue
Try this: turn the power off, take the green and red wires loose from the tstat, twist them together, and turn the power on. If the fan doesn't come on, then you are not getting power to the stat. Do you have a voltmeter, by chance?
TopTechnician is offline   Reply With Quote
Old 06-13-2012, 07:45 PM   #17
Yes I have a volt meter.
aeroknight06 is offline   Reply With Quote
Old 06-13-2012, 07:50 PM   #18
...And did the blower come on?
Old 06-13-2012, 07:50 PM   #19
I twisted the wires and then turned on all the breakers but did not hear anything come on. The blower is in the inside unit correct?
Old 06-13-2012, 07:56 PM   #20
Yes, it is in the inside unit. Put the wires back. Where in your house is the indoor unit? (Basement, attic...). And do you know if you have a condensate pump? Or, does the a/c drain to a floor drain?
Old 06-13-2012, 07:59 PM   #21
The inside unit is upstairs on the 2nd floor. I don't think there is a condensate pump, there is a drain that goes outside. There is a white pipe with a cap next to the upstairs unit that I have been told leads to an outlet next to the outside unit.
Old 06-13-2012, 08:05 PM   #22
Do you feell comfortable taking the covers off of your indoor unit? I'd look for a low voltage fuse next. A picture with the covers off would be great...
Old 06-13-2012, 08:12 PM   #23
Here are some pictures of the upper wiring:
Zoomed into left side:
Zoomed into middle:
Zoomed into right side:
Name:  Inside Right.jpg
Old 06-13-2012, 08:20 PM   #24
I think i see the fuse... Its an automotive type; behind the tan wirenut on the orange wires. It has two blue wires connected to it. Turn the power off before poking around, though! (I see the breaker is off; just making sure it still is)
Old 06-13-2012, 08:25 PM   #25
I see the fuse. If that's the easy fix though it doesn't appear blown. The wire between the 2 halves is still connected and I don't see any black marks. I can get a new one though if you think that's the issue.
Attached is an up close view of the fuse.
Old 06-13-2012, 08:46 PM   #26
With the power on, can you check for 24 volts a/c from R to C on the indoor unit terminal board? I can't see the R terminal, but I assume it is the terminal on the far right...?
Old 06-13-2012, 08:56 PM   #27
I'm not getting any voltage between R & C terminals. Placed the leads on the screws and it's not fluctuating besides a few 0.1 pos & neg. And R is on the terminal block it's the top one.
Old 06-13-2012, 09:02 PM   #28
Check to see that you have 240 volts on the circuit breaker, from the red wires to the black (two bottom connections).
Old 06-13-2012, 09:08 PM   #29
Again not really getting any voltage, only a few tenths when moving the leads. Definitely not 240V.
Old 06-13-2012, 09:12 PM   #30
I neglected to mention that this test was with the circuit breaker turned on... was it on? And no voltage? That would mean you have a problem upstream in the electrical circuit, like in a disconnect, or in the main panel...
Thermostat issue, need help JonMio Electrical 1 02-10-2012 04:40 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Thermostat wiring Problem TRC Electrical 2 09-23-2010 08:37 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Thermostat wiring question cpuken HVAC 4 12-14-2009 08:32 PM
