New Thermostat Wiring - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-25-2011, 10:53 AM   #16
I'm Your Huckleberry
Rewards Points: 2,270
Can you put batteries into the Honeywell so it reads temperature (without being hooked to the system), rest it on top of the new one and see if the temperature readings are the same? Just to get an idea if the stat was bad or reading wrong.
Most stats work on a temperature differential meaning it has to drop one or two degrees below set point before bringing on the heat. I do believe that this is adjustable but these other guys know more about it than I.
I think that is what was happening.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-25-2011, 11:03 AM   #17
Same applies for how high above the temperature set point, I think.
Thanks.
2 zone damper 2 thermostat wiring help kostia HVAC 10 08-22-2010 09:57 AM
Thermostat wiring dimbulb HVAC 16 08-20-2010 11:49 AM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 06:11 AM
Thermostat wiring question cpuken HVAC 4 12-14-2009 07:32 PM
