New Thermostat-system Doesnt Turn Off - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 10:51 PM   #1
Rewards Points: 16
New thermostat-system doesnt turn off
Hi
I just purchased a new Honeywell RTH6400 thermostat and after installation when the heater is on, the system does not turn off. Wires from the wall are Y, W, R, B. I installed Y to Y, W to W, R to R and did not install B, as per the instructions. Everything works but the system does not turn off. When Thermostat is in off position, heat turn off and the fan starts blowing cool air. I have a standard carrier central heat and cooling system around 20 years old. I know its a wiring issue.
Can someone please Help !!!
RICK430 is offline   Reply With Quote
Old 12-08-2009, 10:58 PM   #2
make sure the wires arent touching each other behind the tstat. w to r
also i see no mention of a green term g is for fan on position
kennzz05 is offline   Reply With Quote
Old 12-08-2009, 11:33 PM   #3
Rewards Points: 16
That is correct, there is no G wire coming out of the wall only W, R, Y & B.
Old 12-08-2009, 11:40 PM   #4
than the blue wire must be for fan operation it should be going to a g terminal on the stat
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
FAULTY THERMOSTAT!!! What the He.... Krazecon HVAC 11 02-12-2009 04:26 AM
Thermostat will not follow commands beacu Electrical 5 01-06-2009 10:20 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 10:56 AM
