New Thermostat/ Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2009, 01:01 PM   #1
New thermostat/ humidifier
I recently replaced my AC myself (condenser unit, coil, lineset only) and wanted to update and replace some of my other 15 years old equipment. I have a weathermaker 8000 Two Speed, forced air gas furnace. Its rated at 80,000btu output on high. My thermostat is a honeywell but not sure of the specifics. I do know that it is inaccurate at reading the room temperature. For instance it says the temp is 70*F when my 100 dollars weather temp gauge (that i believe would be far more accurate) says its 67.8*F. but to the point.. ive been reading about an automatic humidifer that i would prefer over my manual one. Its annoying to have to constantly change the setting throught the heating season. I read about the infinity control thermostat from carrier and figured it might be a good investment along with a new humidifier. Just wanted to know if this thermostat would work correctly with my furnace and humidifier. Current humidifer is carrier model-49BF018120. Thanks!
urban23496 is offline   Reply With Quote
Old 10-02-2009, 06:13 AM   #2
An old Tradesmen
Rewards Points: 6,112
Need an Infinty furnace.
Carrier has other stats that will work with your furnace, and humidifier.
Old 10-08-2009, 06:54 AM   #3
okay i figured i needed an infinity system. its the only way for it to make sense. What type of thermostats would currently work with a two speed furnace?
Old 10-08-2009, 11:57 AM   #4
An old Tradesmen
Any 2 stage thermostat will work with non Infinity furnace.
Honeywell has several models that will work fine.
Old 10-08-2009, 12:17 PM   #5
I only have a single stage thermostat now. Is that a problem. Am I going to have any advantages with a new 2 stage thermostat?
Old 10-08-2009, 12:28 PM   #6
An old Tradesmen
With a single stage stat. The furnacces board will have to use its timer to go to second stage.
That makes it jump to second stage when its not needed. And also make you wait for the time period when you want it to reover, if you use set back.
Defeats much of the reason for a 2 stage.
A 2 stage stat will keep it in first stage longer. Providing more comfort. And if you use set back, it will go to second stage quicker, for faster recovery.
Old 10-08-2009, 12:48 PM   #7
Okay so pretty much I could be wasting energy without the proper equipment setup. I will look into getting that new thermostat and hopefully I will save some money
Tags
humidifier , thermostat help
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 06:37 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 11:07 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 10:21 AM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 09:04 PM
